I am just getting into the wedding photography and am shooting my friends wedding on Saturday. Any suggestions on a good lense / lenses to use?
It will be just the reception, she wants mostly candids and it's all indoors at night.
mmmphotography Mostly Lurking 10 posts Joined Nov 2006 More info | Nov 29, 2006 12:43 | #1 I am just getting into the wedding photography and am shooting my friends wedding on Saturday. Any suggestions on a good lense / lenses to use?
thescottandrew Senior Member 906 posts Joined Apr 2006 More info | Nov 29, 2006 12:45 | #2 perhaps the best place to ask this question is in the wedding photography section, youll probably get better feedback. are you going to be using a flash, what focal length do you find yourself using the most?? if you give us more info we can help you even more.
Rhinotherunt Looking for a Rock 7,129 posts Likes: 2 Joined Jun 2006 Location: Jasper, AL More info | Nov 29, 2006 12:47 | #3 Are you the "official" photographer? Weddings are one time things, and have to be done right. Lighting will be a HUGE issue. Second body is a must. Several memory cards too. Lenses from UWA to tele are utilized, but one can use a "normal" focal length fast prime to do it all. Ryan McGill
perfect_pixel Senior Member 454 posts Joined Aug 2006 Location: Salisbury, UK More info | Nov 29, 2006 12:56 | #4 This is just a guestimate but would be my of looking at it assuming this is a casual affair and you are not the only photographer - just there to get some more pictures and practice - as others have said if all of the responsibility is down to you to get the pictures on their big day then you need backup bodies/backup lenses/etc/etc.
Skrim17 The only TPBMer without a title. Enjoying my anonymity. 40,070 posts Likes: 2 Joined Jul 2006 Location: In my tree More info | Nov 29, 2006 12:58 | #5 you don't list your gear, what have you got to do the wedding with? Crissa
kevinsyn Member 127 posts Joined Jun 2006 More info | Nov 29, 2006 13:10 | #6 Rhinotherunt wrote in post #2329707 Are you the "official" photographer? Weddings are one time things, and have to be done right. Lighting will be a HUGE issue. Second body is a must. Several memory cards too. Lenses from UWA to tele are utilized, but one can use a "normal" focal length fast prime to do it all. Personally I dont 100% agree with all of this. Lighting is a huge issue but thats one thing the "photographer" will always try to fight with and compete with. But learning how to adapt to any lighting situation is what makes a great photographer. Second body is definately not a "must". www.kevinsyn.com
Rhinotherunt Looking for a Rock 7,129 posts Likes: 2 Joined Jun 2006 Location: Jasper, AL More info | Nov 29, 2006 13:28 | #7 kevinsyn wrote in post #2329821 Lighting is a huge issue but thats one thing the "photographer" will always try to fight with and compete with. But learning how to adapt to any lighting situation is what makes a great photographer. Fast primes are great but most of the time your lighting situation is going to be so horrid that even the 1.2 isn't going to save you. Speedlite or a flash gun is definately a must imo. I did not mention a speedlight, but kinda figured it was understood when I stated that lighting is going to be the biggest issue. I recommend the fast prime route due to the cost of faster zooms. Most consumer zooms are quite slow. One could get a Tamron 28-75 2.8 and a speedlight and do very well however. Ryan McGill
Nov 29, 2006 13:59 | #8 Thanks for all your advice. No, I am not the primary photographer, just helping a friend out with some extra shots. I have the 20D with the 18-55mm lense. I was planning on renting all my equipment, so far I know I need the 580EX flash but am unsure about a lense.
kevinsyn Member 127 posts Joined Jun 2006 More info | Nov 29, 2006 14:03 | #9 mmmphotography wrote in post #2330087 Thanks for all your advice. No, I am not the primary photographer, just helping a friend out with some extra shots. I have the 20D with the 18-55mm lense. I was planning on renting all my equipment, so far I know I need the 580EX flash but am unsure about a lense. Work with what you've got or work with gear that you will buy. www.kevinsyn.com
Rhinotherunt Looking for a Rock 7,129 posts Likes: 2 Joined Jun 2006 Location: Jasper, AL More info | Nov 29, 2006 14:27 | #10 kevinsyn wrote in post #2330107 Work with what you've got or work with gear that you will buy. 430EX works just as well as the 580EX, even the sigma 500dg and such. Ditto^^ Ryan McGill
genecx Member 32 posts Joined Dec 2001 More info | The 28-70 2.8L is my lens of choice for weddings. I usually have a second body with the 70-200 2.8L handy, but it hardly gets used. And I have a couple of 550EX flashes. I never felt the need for a WA lens because of the way I shoot (PJ style, with lots of closeups).
aliflack Senior Member 401 posts Joined Aug 2004 Location: York, UK More info | Nov 30, 2006 06:52 | #12 perfect_pixel wrote in post #2329748 If it is at night and indoors then it would seem to me that you are going to want primes for their larger apertures. If it is just for the reception then you probably only want one lens which is versatile enough with a bit of foot zooming to grab candids as they happen and you won't have to worry about swapping lenses. So in my amateur logic I would go for either the 35 or 50mm primes. The 35 is a F/2 or F/1.4L. The 2 may be too slow and the 1.4 might be too expensive. The 50mm is 1.8/1.4 or 1.2L. The 1.2L is WAY too expensive, the 1.8 is slow to focus. QED: The lens you want is the EF 50mm F/1.4 USM (IMHO) Disclaimer: This could be total c**p and I accept no responsibility should it turn out to be so..!! I would totally disagree with this - the one advantage that a prime might offer you in this situation is a brighter viewfinder and improved focusing ability as a result. The large aperture won't be useful when taking the majority of shots as you will need to stop down to get sufficient DOF. Get a fast zoom (seconding the suggestions of 24-70 F2.8, either canon, sigma or tamron) and use high iso to get your backgrounds to the right exposure and your flash to expose the foreground. 40D, 16-35L F2.8, 24-70L F2.8, 70-300mm IS, 100mm F2.8, 85mm 1.8, 50mm 1.8, Elinchrom D-Lites, Mid Octa, 580 EX
MikeMcL Goldmember 1,411 posts Likes: 1 Joined Jun 2006 Location: Dayton Ohio More info | Nov 30, 2006 07:07 | #13 sigma 30mm 1.4 is a good budget lens for this focal length. also read up on indirect flash, and get at least a 430ex, they work great in mostly any situation. remember to use ISO as needed, and chimp the histograms after most shots. aim to shoot at f4 and open the aperature a bit when you really need to. 350d, 5d, 28-70L, 70-200L, 430EX,
darktiger Goldmember 1,944 posts Likes: 13 Joined Oct 2005 More info | Nov 30, 2006 08:18 | #14 I say rent/buy a 430 and rent a 24-70f/2.8 if you can...
KevNJ Senior Member 366 posts Joined Jun 2005 Location: NJ-USA More info | Nov 30, 2006 10:52 | #15 I provide rental equipment. Will be updating the site later tonight cause theres some packages at the post office that were rented out. Link in sig. Kevin
| Latest registered member is Thunderstream 1220 guests, 123 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
