Thread started 29 Nov 2006 (Wednesday) 15:14
I have a question about point #28 in the tips sticky...
col4bin
Joined Feb 2006
Nov 29, 2006 15:14 |  #1
#28 Set your f-stop deep and focus a third up the image to get good front to back focus
do most people normally use the lower middle focus point (on a 9 point system)?
Frank
http://www.fiorentinop​hotography.com (external link)
rudgej
Couch-potato photographer
Nov 29, 2006 16:16 |  #2
That tip is to do with hyperfocal focusing Frank, and is not directly related to which focusing point on the camera that you use. Indeed for hyperfocal focusing you will manually focus anyway.
Briefly stated hyperfocal focusing is based on the fact that the depth of field of the subject focused upon extends 2/3s behind that point, and 1/3 in front of it. If you are focused at infinity, then this 2/3s zone is wasted. By manually focusing at an area closer to you than the main subject, you can effectively make more of your foreground appear in focus. This hyperfocal focusing (external link) article will explain it better than me. :)
col4bin
Joined Feb 2006
Nov 29, 2006 17:25 |  #3
I think this hyper focus thing juts clicked for me. Am I correct in stating that once you calculate the hyperfocal distance, you need to manually focus on that point?
Frank
rudgej
Nov 30, 2006 02:09 |  #4
col4bin wrote in post #2331017 (external link)
Not necessarily, if there happens to be a useful landmark (e.g. a boulder) at that distance, then you could use your camera's focus points on that. However, manual focusing is a common way of doing it. For instance, Dimitri (dv2004) has a little DEPSSI (external link) card that lets him read off what distance to focus on given his focal length and aperture, and he then just adjusts for this distance on his lens.
AdamJL
Nov 30, 2006 04:55 |  #5
rudgej wrote in post #2332668 (external link)
Ahh! So that's how the Master does it?! Nice one, the sincerest form of flattery is imitation, so I'm going to buy one of these :)
Gear
1,105 views & 0 likes for this thread, 3 members have posted to it.
2704 guests, 137 members online
