Thread started 29 Nov 2006 (Wednesday) 19:07
Hey Audiophiles! Part Deaux
cdifoto
Don't get pissy with me
Nov 29, 2006 19:07 |  #1
Ok I received my Sennheiser HD-280 Pros today. I'm very very pleased with them but....
I want to purchase a highly portable equalizer or equalizer/amp combo to run between the 'phones and the laptop. It has to be small in keeping with the idea of portability. After all, that's why I bought the laptop in the first place. It doesn't have to be a real complex EQ - ie 3 channel control is enough for me.
I looked at supercheap, namely the Koss ED50 or something, and it had terrible reviews. So that one's definitely out. I'm really not looking to spend more than I paid for the headphones - so let's say $80 MAX. No stretching the budget like I did with the headphones. I just can't do that. I'd rather have no EQ at all than go overboard. I like the sound as they are, but if I can really make them wow me for a reasonable extra cost, why not!
So does anyone have any ideas? Remember - $80 max budget and highly portable.
SgWRX
Joined Jun 2005
Nov 29, 2006 23:36 |  #2
well, i have some type of wild in-box sound card with 5.1 digital surround capabilities and was horrified the first time i hooked up my senn hd545's to it to listen to music. a friend recommended i get an external sound card, so i got a soundblaster live external usb and plugged the headphones in it. HUGE HUGE difference. enough that i can discern the difference between an MP3 file encoded at 384kb vs a full on wave file.
getting the sound card away from the computer internals and all the noise interference like CPUs blew me away. i didn't go overboard either with the usb external sound card either, as i recall it was about $99 a couple years ago.
cdifoto
Nov 30, 2006 06:17 |  #3
Just want an EQ, thanks.
Zepher
Joined Nov 2005
Nov 30, 2006 06:30 |  #4
is there anything wrong with the software EQ's for the PC?
Manny Desantos
Intel C2Q Q6600 3.06Ghz, 8GB Ram, 8.1TB, XFX HD5850, Windows 7 Ultimate 64bit, PS CS4 EXT (external link)
Canon 40D, EF 28-70L, 2x Canon XH-A1 HDV, Canon HV30 HDV
❶_______________
cdifoto
Nov 30, 2006 07:03 |  #5
Zepher wrote in post #2333168 (external link)
My sound card doesn't have any controls available to it. I checked on the downloadable type but didn't really know what would be a good choice.
dmp-potn
Nov 30, 2006 07:31 |  #6
Hello,
This little $29 device might do the trick (has 10-band eq and digital audio out as well):
http://www.turtle-beach.com/site/product​s/audioadv/micro/ (external link)
If you decide to try it, let me know how you like it. I would ike to pick up something like this as well.
-- David
cdifoto
Nov 30, 2006 07:38 |  #7
dmp-potn wrote in post #2333326 (external link)
Hello,
Interesting. I'm not a fan of thumb drives since I tend to lose things, but I've bookmarked it.
dmp-potn
Nov 30, 2006 07:43 |  #8
Hello,
Perhaps look at this one as well:
http://www.turtle-beach.com …dv/roadie/produ​cthome.asp (external link)
Good luck!
-- David
dmp-potn
Nov 30, 2006 08:08 |  #9
Hello again....
Of course, if cost was of little concern, this would be the thing to get:
http://www.headphone.c​om …eadroom-total-bithead.php (external link)
I use one of their desktop headphone amps with my HD 600's, and it works great. I didn't know that they had a USB audio amp, but thought I'd check. Sure-nuf, they do. only $200. :-)
-- David
Bob_A
Gallery: 48 photos
Joined Jan 2005
Nov 30, 2006 08:14 |  #10
cdi-ink.com wrote in post #2333256 (external link)
What are you using as software to play your music on your PC? Media Player has a 10-band equalizer and RealPlayer has a 3-band one, upgradeable to 10-band.
Bob
cdifoto
Nov 30, 2006 08:24 |  #11
Bob_A wrote in post #2333414 (external link)
I stream audio through Yahoo Messenger's Radio. I don't download my own stuff, and the controls are non-existant on the Messenger. All they give you is volume, play, pause, and skip. Not exactly meant for hi-fi listeners but it gives me the tunes I want and is a lot less expensive than legal downloads. :)
cdifoto
Nov 30, 2006 08:30 |  #12
dmp-potn wrote in post #2333351 (external link)
Hello,
Good luck!
Bookmarked. Thanks for the links. I have to find out all my options before I decide, if I even buy anything at all.
dmp-potn wrote in post #2333397 (external link)
Hello again....
I was looking at that. It's an amp though and not an EQ. I don't have any problems with volume. I'm typically only needing 20-40% on the laptop. It seems to have a really good quality sound card already, for a laptop, at least to my own non-expert ears.
sjafari
Nov 30, 2006 08:30 |  #13
If you want better sound, i feel like the best way is to get the sound card off the motherboard, like SGwrx said. Being that you dont want that, any cheap equalizer will probably degrade the quality of the sound more than you would want. You could try to work with a small portable headphone amplifier, which will give your bass a good kick in the pants.
-Shehab-
http://www.fotojafari.​net (external link)
5Dii, 16-35/2.8ii, 24-70/2.8, 135/2
cdifoto
Nov 30, 2006 08:35 |  #14
sjafari wrote in post #2333458 (external link)
Eh it's not a sound card issue really. I've listened to the audio on DVDs and the sound is there. It's Yahoo Radio that I need to "tweak" a bit and I believe an EQ would let me do that. It's not that bad though so I could really do without. I'm not going to go cheap because, like you said, it can degrade quality.
I probably have one of the quietest, cleanest laptops on the planet though. I don't have any interference or hard drive noise, etc so getting the sound card out of the computer probably wouldn't make much difference.
sjafari
Nov 30, 2006 09:05 |  #15
what kind of laptop are you using? my (work provided) Dell D620 gets some hefty interference some time from the trackpad being used. if you like the simple free music sites, Pandora is really good too.
-Shehab-
2,647 views & 0 likes for this thread, 9 members have posted to it.
1797 guests, 121 members online
