Thread started 30 Nov 2006 (Thursday) 22:49
Connecting 1Ds To PC
Photoman65
Nov 30, 2006 22:49 |  #1
I am not a CPU expert, but does anyone know how to use connect their 1Ds AV out to work on a PC. I am able connect the 1Ds to my TV for picture display, but I am unable to connect the 1Ds to my PC to view pictures as they are snapped. Any suggestions how to do this is greatly appreciated.
BTW, I am using a Toshiba Lap Top
Canon USA Gear! Cameras: 5D MKIII & 7D L Lenses: 24mm-70mm f/2.8, 85mm f/1.2 II, 70mm-200mm f/2.8 IS, 1.4II Ext, 580 EXII Speedlite
infinite012
Dec 01, 2006 01:56 |  #2
Use the supplied USB cable instead of the AV cable. You will be unable to use the AV cable with the PC unless you have a TV tuner card installed.
Once you have the 1Ds connected, you should be able to use whatever Canon proprietary software to shoot in a "tethered" condition (i.e. the computer can control the camera or the camera can control the camera).
That's how it works with the 350d, at least.
Michael
Jon
Joined Jun 2004
Dec 01, 2006 07:49 |  #3
With the 1Ds you need to use the FireWire connection, if your laptop has one. Av out will only work if you have a multi-media PC with a video in port, and you'll have to run the TV/viewer app then.
Jon
Cocker Spaniels
Woolburr
Rest in peace old friend.
Gallery: 115 photos
Dec 01, 2006 07:53 |  #4
You will need to use the firewire cable and some version of Canon software to get it to function correctly.
930 views & 0 likes for this thread, 4 members have posted to it.
1929 guests, 122 members online
