Thread started 01 Dec 2006 (Friday) 12:19
Sigma Lens Problem?
magicmikey
Dec 01, 2006 12:19 |  #1
I recently purchased a Sigma 17-70mm zoom lens for my XTi. I had read a lot about and had noticed that some people had to exchange theirs for a "good copy."
I did a quick focus test when I got it to make sure it didn't have a severe front or back focus issue and it looked okay, except the right side seemed sharper than the left. I just assumed I hadn't lined up the camera accurately.
I then started using the lens. I took some family shots over Thanksgiving and noticed that the left side was consistently softer than the right so I decided to some more testing.
Well, it appears that the lens is out of alignment. The right side is consistently sharper than the center and the left side is pretty soft, in comparison.
I've talked to B&H Photo and they're sending me the return shipping info but I just am wondering if I'm making too big a deal of this. Here is a sample comparing the left side, center and right side. It's taken on a tripod at f/8.0 in Raw. The only PP I did was to adjust the levels and white balance. These are sections at full size (36" x 54" at 72 dpi.)
http://xs410.xs.to/xs4​10/06485/SigmaTest.jpg (external link)
I'd like to hear whether you think I should send it back or not. I really like the lens otherwise. (I'm going to post this on dpreview as well.)
Thanks,
Michael
05Xrunner
Goldmember, Flipflopper.
Gallery: 52 photos
Dec 01, 2006 14:11 |  #2
how far away where u from the paper.
also how does it do when taking real pics not pics of trying to see if its messed up
My gear
R7, 7D, Canon RF 14-35 f4L, Canon RF 50 1.8 STM, Tamron 70-200 G2, Canon 100-400LII, Canon EF-RF
TMR ­ Design
Joined Feb 2006
Dec 01, 2006 14:19 as a reply to  @ 05Xrunner's post |  #3
What AF point are you using? I would also like to see some real world pictures.
Robert
condyk
Africa's #1 Tour Guide
Dec 01, 2006 14:21 |  #4
It's a great lens but yours doesn't look so good. I would accept the replacement and try your luck. That does look out of alignment. I assume it was square on a tripod. If not the results can't be trusted. Seems like in real world shooting you had similar issues, in which case send it back.
https://photography-on-the.net …/showthread.php​?t=1203740
nismosr
Dec 01, 2006 14:43 |  #5
what! i just order this lens yesteday i hope mine doesnt come like that ..
Canon 5D2, 50mm F1.2L, 35mm F1.4L,580ex II
Mr. ­ Clean
Dec 01, 2006 14:45 |  #6
If that paper is for certain square to the lens then I'd swap it out or send it in.
nismosr I'm sure yours will be fine. It's one post.
Mike
some shots @ Zenfolio (external link)
05Xrunner
Gallery: 52 photos
Dec 01, 2006 14:45 as a reply to  @ nismosr's post |  #7
I think this is the first I ever heard of the 17-70 not being up to par....I am sure this is only a rare case...
My gear
Nick_C
Dec 01, 2006 14:50 |  #8
This isnt only limited to Sigma, ANY make of lens has duds knocking around, you can be unlucky with anything, if your even the slightest bit unsure you should send it back for an exchange.
The 17-70 is sharp edge to edge & definately should NOT be worse on one side, I make my 17-70 do everything, landscapes, the odd portrait, family photos, macro etc..
This is a recent shot I took using my 17-70, you should be getting very sharp results, if not then return it straight away, you dont want to be left with a lemon!
Nick :-)
dtngo
Dec 01, 2006 15:25 |  #9
Definately get a replacement or get it serviced by Sigma. The 17-70mm produces sharp pictures all around, so why settle for a below par copy?
Great pic Nick_C. only resized or cropped too? I'm assuming PP, otherwise that's a brilliant copy!
Dac | www.dtngo.com (external link)
Canon 5D | 350D + BGE3 | 17-40L | 24-70L | 50mm f/1.4 | 85mm f/1.8 | 70-200 F4L
| 430ex
Nick_C
Dec 01, 2006 17:21 |  #10
Thanks egghead, that was uncropped, all I did was resized for the web with a little sharpening which is usually needed on DSLR images anyway.
It is a great lens, works very nicely on macro shots too.
Nick :-)
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Dec 01, 2006 18:59 |  #11
Its a shame you got a bad copy, I can't believe how well liked it is around here, just shows how good it can be.
But, the more the sell, the more bad ones get through.
Hope sending it back is relatively painless, and the new one comes from the other end of the quality curve :)
At F8 it should be an awful lot sharper than that!
I know mine certainly is.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
1,260 views & 0 likes for this thread, 9 members have posted to it.
Sigma Lens Problem?
1594 guests, 139 members online
