...but does it really matter?
The reality is that perfectly exposed piccies of beautifully timed, frame-filling peak action can be very enjoyable to look at... but, let's face it, the bread and butter of shooting at the sharp end is capturing the goals and images that illustrate the underlying story of the game. You're not always going to be in the perfect spot every time and working in optimum conditions, so you have to work hard with the cards you've been dealt.
I rarely post goal pics as they don't generally make for interesting stand-alone images... but, in the spirit of breaking the habit of a lifetime, here are a few (ropey) images from Tuesday night's Colchester vs Hull match and some associated waffling. It was a fairly eventful night:
1. Hull took an early lead through Nicky Forster. A story was already developing as Colchester were undefeated at home for seven matches... so this image was (for a short time) newsworthy...
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
2. Better still when Forster ran in my general direction to celebrate.
3. Don't count your chickens though. Within a few minutes Colchester had equalised... and Hull's (ex-Colchester) manager Phil Parkinson started to get a bit grumpy with the referee's assistant. This was Parkinson's first match back at Colchester with his new club...
4. Things went from bad to worse for Hull when Chris Iwelumo was brought down in the box...
5. ...and converted the resulting penalty to put his side 2-1 ahead...
6. The ever-lively Jamie Cureton scored an excellent solo goal to make it 3-1. Yep, this is a major crop at 1/400s taken with the 70-200mm from the opposite side of the penalty area, a recipe for disaster...
7. Even better! No ball whatsoever... and this is Iwelumo's hat-trick goal... aaaargh!
In fact, it was at this moment that one of the MkII bodies I was shooting with decided to give up the ghost. In the burst of five frames I shot, this was the only one in focus. All the other frames were all over the place. The reason: shutter/mirror box failure... and off to Fixation for a repair. Still, I needed an excuse to buy a third body. Hmmmm.
8. Back to the underlying story... Phil Parkinson was (unsurprisingly) tight-lipped when facing the media after the game...
Ta for having a peek.
---- Gavin
because I am trying to find a buyer for my soul so I can get just one
