Thread started 01 Dec 2006 (Friday) 20:51
Quick question about shutter speed @ 200mm w/ IS
emtp563
Dec 01, 2006 20:51 |  #1
What is the lowest handheld shutter speed you can use at 200mm using IS?
I'm considering the 70-200L f/2.8 IS.
What's the lowest shutter speed you can handhold using the 70-200L f/4 IS? Is it one or two stops lower than the 2.8's IS?
*cameras: Canon 1D Mark III | Canon 1D Mark II | Canon 1D "Classic" | Canon S95
*lenses: Canon 16-35L f/2.8 | Canon 24-70L f/2.8 | Canon 70-200L f/2.8 IS | Canon 1.4x TC II
*accessories: Canon 580EX II/430EX | Quantum Turbo SC | CP-E4
http://www.cyclingcapt​ured.com (external link)
http://www.facebook.co​m/cyclingcaptured (external link)
Jon
Joined Jun 2004
Dec 01, 2006 21:59 |  #2
Should be, given Canon's description of the f/4 IS, about the same light level, maybe a stop slower shutter speed than the f/2.8 IS. That's only if you give the camera a longish time to spin up the IS mechanism.
Jon
Cocker Spaniels
luant16
Dec 01, 2006 23:48 |  #3
1/25 with good result, 1/15 - 1/20 with luck
emtp563
Dec 02, 2006 09:43 |  #4
luant16 wrote in post #2341535 (external link)
Are these speeds at 200mm?
SkipD
Joined Dec 2002
Dec 02, 2006 09:58 |  #5
I took a shot last year with my 20D, fitted with my 70-200 f/2.8 IS screwed to a Canon 1.4x extender, for a real focal length of 280mm (equivalent to a 448mm lens on a 35mm film camera). It was such a fast shot that I failed to look at the shutter speed - it was 1/15 second. The shot came out a little blurred due to handheld instability, but was quite acceptable under the circumstances. The shot is attached to this thread if you'd like to see it.
Skip Douglas
Tapeman
Sliced Bread
Joined Jan 2004
Dec 02, 2006 12:45 |  #6
1/60 th consistantly. 1/30th often
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
Glenn ­ NK
Dec 02, 2006 13:50 |  #7
Tapeman wrote in post #2343474 (external link)
These seem reasonable - with my 24/105 racked out, I can get 1/30th consistently, 1/15th often. And 1/10th occasionally.
When did voluptuous become voluminous?
ScottE
Joined Oct 2004
Dec 02, 2006 14:06 |  #8
The lowest hand hold shutter speed depends on how sharp a picture you need, your ability to hold the camera steady, what percentage of acceptable pictures you want and whether the subject moves. There is no answer that is meaningful for all situations and the best you can hope for is a rule of thumb or what other people find acceptable for their ability and standards.
The only important factor is that you can shoot at get the shutter speed with an f/2.8 lens that you do with an f/4 lens in low light situations. As long as the depth of field is sufficient, that gives more choice over ISO setting and the ability to shoot moving subjects. If we have to shoot wide open, we don't have control over the lighting so we want the lens that is most capable in the worst conditions we are likely to encounter.
In my mind the choice between the f/4 and f/2.8 versions of the 70-200 is a choice between the lower cost and less bulk and weight of the f/4 vs. the better low light capabilityies of the f/2.8 and the 77 mm filters that are interchangeable with a great number of other L and EF-S lenses.
1,368 views & 0 likes for this thread, 7 members have posted to it.
1602 guests, 123 members online
