Paul91 wrote in post #2343977
Hello, I was wondering how good the Canon EOS 1Ds mark II is? And what is an actuation count? Is this the # of shots u can take? And if i go past this # is the camera good for nothing now, if it is could i buy something like a new battery or memory card (does a batter or MC have new actuation counts)? PLEASE ANSWER!
It is Canon's top of the line camera...as Liza previously mentioned. I own the 1Ds and it still amazes me on on a regular basis, the Mark II has even more features and better imaging components.
The actual actuation count is the number of times the shutter mechanism has been opened and closed. Canon and most other manufacturers have developed MBTF (mean time between failure) data for most of their cameras and components. The expected MBTF for the 1Ds Mark II is 250,000 actuations. Individual results can vary. The shutter assembly is a fairly inexpensive repair in the grand scheme of things and the camera will then be good to go for an additional large number of images. Canon has authorized service centers located around the globe...all of which can perform the repair should the need ever arise.
The battery used by the camera is rechargeable. It has no direct bearing on the number of overall actuations that a camera can do. There are however, a range of actuations that can be performed with a full battery before it requires recharging. Again, this varies widely by the type of use, temperature and other conditions. Just charge the battery and begin shooting again.
The memory card also plays no direct role in the number of actuations the camera can perform. Each card can only hold a finite amount of data. When the card is full, you must either download the images to a computer or other storage device or utilize another memory card until such time as you can remove the images from the card. Once the images are transferred to another storage medium....the memory card can be reformatted or erased and used again and again.
