Thread started 03 Dec 2006 (Sunday) 00:43
flash?
luannf1980
Dec 03, 2006 00:43 |  #1
I bought a flash for my 20d, the 430ex i put it on and turn it on..and it wont charge up or test flash..the cam acts like it is not there... Can anyone help here? What am i doing wrong?
blonde
Buck Naked Floozies
Dec 03, 2006 00:44 |  #2
need a bit more info. did you tighten the wheel on the hot shoe mount? can you tell us what you see on the flash? what mode are you using on the camera? did you use a fresh set of batteries?
drparker
Dec 03, 2006 01:04 |  #3
Will it flash if you press the pilot button?
Join us in Chicago on April 22nd (Click here for more details)
5D, 85 f1.8, 24-70L[COLOR=black] f2.8, 70-200L f/4, 580ex, 430ex.
Titus213
Dec 03, 2006 01:17 |  #4
The flash doesn't charge on the camera. You have to put batteries in it.:D
In the creative zones the camera will not 'see' the flash. P mode will react to the flash. Av, Tv, M do not see the flash. They still just measure ambient light and react to that.
Dave
Perspiring photographer.
Mike ­ Philippens
Joined Jun 2005
Dec 03, 2006 01:41 |  #5
Titus213 wrote in post #2346096 (external link)
The camera sees the flash in all modes. It just changes it's behaviour in those modes, but it will fire a flash (if it's on ;)). To fully understand the EOS flash system, you should read the EOS Flash bible (look in the sticky FAQ in the flash section).
1D MkI+MkII=MkIII
Titus213
Dec 03, 2006 08:46 |  #6
Mike Philippens wrote in post #2346145 (external link)
You are correct, the camera 'sees' the flash. It just gives no indication exposure wise that the flash is there which is what my comment was about.
Dave
jra
Dec 03, 2006 08:48 |  #7
My first thought exactly :) Did you put batteries in your flash?
luannf1980
Dec 03, 2006 09:12 |  #8
yes of course i put batteries in the flash...ive done all that it says to do...the pilot light does not light up.. the camera is not reconizing that it is there..in any mode..?
jra
Dec 03, 2006 09:16 |  #9
You may want to make sure your batteries are in properly (it's easy to get them in backwards, I've done it plenty of times). If that doesn't work, maybe try some different batteries. If all else fails, I would say you have a defective flash.
drparker
Dec 03, 2006 11:15 |  #10
luannf1980 wrote in post #2347021 (external link)
As jra says. If you've replaced the batteries with new ones and sure they're installed correctly and the pilot does not light either on or off the camera then you've got a bad unit.
885 views & 0 likes for this thread, 6 members have posted to it.
flash?
1602 guests, 123 members online
