Thread started 03 Dec 2006 (Sunday) 18:19
Help with photo?
Geo
Dec 03, 2006 18:19 |  #1
Hi for all, yesterday I was to take a picture of "El Duque Hernadez" here in Miami, the reason is that I was willing for this shot a lot, but in the moment of the shot I don't know what happens when I set up my camera I don't set up correctly the WB. The W.B was in fluorescent, when I was to check it out the picture was horrible, very, very bad. with strong blue cast. I trait to fix in photo shop but I am feel frustrate.
Some vary else can help me please?.
I am new in forums and my English no is so good, I am sorry for that.
How can I attachments a file at this message???????
flickr (external link) FACEBOOK (external link) Canon EOS 5D mark II, Canon EOS 7D,Lens: Canon 24-70 mm 2.8 L, 85 mm 1.8, 50 mm 1.8 Canon 70-200 mm 2.8 [COLOR=Red]L IS[COLOR=Black], Tokina 11-16mm 2.8 , 16-35mm 2.8LII-Flash: Canon 430 EX, 580 EX II, Extender EF 2X II, and much more stuff.
In his own words, "I don't photographer the world as it is. I photographer the world as I would like it to be." Monte Zucker.
Jman13
Dec 03, 2006 18:30 |  #2
You can fix WB issues in Photoshop by using Curves, and adjusting each channel of the photo. Unfortunately, shooting in JPEG, you are going to have some quality loss when you mess with the image.
It won't help you for this shot, but in the future, you may want to look into learning how to use RAW, as you can set the white balance after the shot with RAW.
Jordan Steele - http://www.jsteelephot​os.com (external link) | https://www.admiringli​ght.com (external link)
Canon EOS R5 | R6 | TTArtisan 11mm Fisheye | Sigma 14-24mm f/2.8 | RF 24-105mm f/4L IS | Tamron 35mm f/1.4 | RF 35mm f/1.8 | RF 50mm f/1.8 | RF 85mm f/2 | RF 70-200mm f/2.8L IS | Sigma 135mm f/1.8
ggw2000
Dec 03, 2006 18:37 as a reply to  @ Jman13's post |  #3
Geo, do you have a picture host site? Pbase/Imageevent/etc.. If not you can email the picture and I can post it for you. Gerry
Geo
Dec 03, 2006 18:43 |  #4
Thank you for your help but I dont have host site. you can email me and then I will gave yo a pictures. Thank you Gerry.
Geo
Dec 03, 2006 18:45 |  #5
Any help in any book of use RAW Jman13?
tdaugharty
Dec 03, 2006 19:01 |  #6
Well you have a 30D and should consider custom WB. This means you'll have to learn how to use a WB card or an expo disc to set WB but in the end you'll certainly come to the conclusion this is allot of work and can do the same thing in RAW.
RAW processing requires development of a good workflow. The recommendation I have for you around processing raw images is to consider use of C1 from PhaseOne. It's easy to use and powerful.
So in the end it's either get the WB right on exposure or make it right in RAW. Either way it's an either or path. AWB is just not good enough to cover some circumstances.
As for the expo disc it's really only good for indoor conditions where light is constant. Reason for this is by the time you shoot with the disc on and set custom WB to use the image the light will probably change.
One quick fix you might try on your image is to neutralize the color cast. Try this little nugget. Open the image and under image adjustments click match color and then click the neutralize option and see if that will bring balance back to the image.
Another option is to use WB presets in the camera (Look in the manual). These can save you when AWB can't figure out appropriate settings.
Canon 5D / XTi - Epson R1800 - Sekonic L-558R
580EXII Speedlite / 430EX Speedlight / Strobes / Props
EF-S 17-55 f/2.8 IS / 24-105mm f/4L IS / 70-200mm f/2.8L IS / 100-400 f/4.5L IS
ggw2000
Dec 03, 2006 19:10 as a reply to  @ tdaugharty's post |  #7
GEO, sent you email.. Gerry
Geo
Dec 03, 2006 19:32 as a reply to  @ ggw2000's post |  #8
Ill trait.
Jman13
Dec 03, 2006 21:57 |  #9
tdaugharty, excellent tip on the match color...didn't even know it was there. I'd taken a look at the match color command when I got my upgrade to CS2 from 7, and haven't visited it again. Proof that you can always learn a LOT more about photoshop, even after 8 years of using it.
992 views & 0 likes for this thread, 4 members have posted to it.
Help with photo?
1604 guests, 122 members online
