Thread started 04 Dec 2006 (Monday) 20:57
Portrait setting on S2 IS...I give up!
mommytomjm
Dec 04, 2006 20:57 |  #1
Ok, for a week I have been trying to figure out the portrait setting on my camera and I can't get it to work....Everything is always in great focus instead of the subject being focused and background being blurred. What am I doing wrong?
Andrew, Bonny and MJ
See my pics at The Spot (external link)
Proud owner of a brand new Powershot S2 IS
strmrdr
Dec 04, 2006 21:00 |  #2
lower the f-stop and put more distance between the subject and background.
4-7 feet behind might be needed.
ΜΟΛΩΝ ΛΑΒΕ
Cindi
Dec 05, 2006 07:53 |  #3
strmrdr wrote in post #2354701 (external link)
I don't think you have control over the f-stop in portrait mode. I don't have my camera with me to test this right now. The other recommendation about having some distance between your subject and the background is good advice. Give that a try. I tried portrait mode once and I must have gotten really lucky with my results. I filled most of my screen with my nieces head and the background was quite a way behind her and it turned out beautifully. Don't give up yet, you will get it. :)
~ Cindi ~
Rebel XTi/kit lens/nifty fifty
Powershot S2 IS
mommytomjm
Dec 05, 2006 12:01 |  #4
Thanks for the encouragement. Still no luck on the Portraits..I'll keep trying, but I can change the ISO, F stop and Exp I layed in bed last night and changed one setting at a time and took pictures of something across from me so I could compare them all with the different settings. (Okay, so I'm a little obsessed wtih my new camera...)
scott1120
Dec 05, 2006 13:12 |  #5
mommytomjm wrote in post #2354679 (external link)
According to the S1 manual the Portrait setting: I know you are using the S2, hopefully no difference
You can achieve a better blurring effect of the
background by making sure the upper half of your
subject fills the entire LCD monitor (or viewfinder).
You can enhance the blurring effect of the
background even more by setting the lens to its
telephoto end setting.
You also cannot change any settings (shutterspeed, f/stop)
Scott
Canon S1 IS
Permagrin
Dec 05, 2006 13:17 as a reply to  @ scott1120's post |  #6
you might try extending your minimum focus distance. I noticed, when I had the S3, that it would take the shot, but if I was too close to my subject, the subject would be blurry and the background would be sharp. You can't change many of the functions in those modes. The only other way you can get the settings you want is to switch to AV mode, set the aperture to 2.8 (this will blur the background nicely) and focus on your subject. You'll still have to make sure you are far enough away not to have the camera swich focus points (not adjustable) on you....
Woogie
Dec 05, 2006 13:21 |  #7
try doing headshots at right around 7x or 8x. It'll help you get a better understanding of how to achieve the best bokeh.
Dori
Dec 06, 2006 23:19 |  #8
I dont know if this will help but here is a shot I did that has a blurred background (bokeh)
IMAGE: http://static.flickr.com/110/267416349_8f606915cf.jpg
And here is the Exif data
Shooting Mode
Manual
Photo Effect
Vivid
Tv (Shutter Speed)
1/60
Av (Aperture Value)
3.5
Light Metering
Center Weighted Avg.
ISO Speed
50
Lens
6.0 - 72.0mm
Focal Length
45.2mm
Digital Zoom
None
IS Mode
Shoot Only
Image Size
2592x1944
Image Quality
Superfine
Flash
Off
White Balance
Cloudy
AF Mode
Continuous AF
Color Space
sRGB
Canon 350D, Canon 40D
18-55mm, Canon 75-300mm, Canon 50mm F/1.4, Canon 70-200mm f/2.8L IS,
Sigma 24-70mm f/2.8 EX DG, & Speedlite 430EX.
My Flickr (external link)
ingi
Dec 06, 2006 23:32 |  #9
I agree with permagrin, ditch the portrait setting and use av mode. As long as you use your zoom to fill the frame with your subject and have them sitting at least 1-2 metre away from your background (more if you can). Use f2.8, f3.5 you should get a beautiful blurry background
INGRID
A camera is but a mirror with a memory
S3IS and canon lenses
www.flickr.com/photos/​esti_ingi (external link)
DanteCaspian
Dec 07, 2006 21:42 |  #10
Permagrin wrote in post #2357567 (external link)
Oh man, know I know why some of my recent shots did this!
mommytomjm
Dec 10, 2006 21:27 |  #11
Well, I did it! I did it inadvertantly, but I did it...I took a series of pictures of a hawk on a pole at Animal Kingdom and when I started to review the photos tonight I discovered this....
Tony ­ The ­ Pony
Joined Feb 2006
Dec 11, 2006 08:22 |  #12
good for you! something that also will help you increase your blurred backgroun shots is to stand far enough away where yo9u can zoom all the way in on your subject, then you can focus on it and the backgroudn ususally will become blurred
mishnogram
Dec 11, 2006 19:47 |  #13
Using some of the same advice as given on this thread, I have been able to get some great shots with blurred backgrounds.
non-macro mode picture.
IMAGE: http://lee-family.smugmug.com/photos/84552883-M.jpg
Taken at near maximum zoom
IMAGE: http://lee-family.smugmug.com/photos/62158540-M.jpg
Min
Canon Rebel xt with kit len, Sigma 55-200mm F4-5.6 DC, Canon S2IS, & not enough time to use them all.
http://picasaweb.googl​e.com/mishnogram (external link)
Tony ­ The ­ Pony
Joined Feb 2006
Dec 11, 2006 19:48 |  #14
i love the first one, very nice bokeh
Cindi
Dec 12, 2006 07:37 as a reply to  @ Tony The Pony's post |  #15
The first one is great!!
~ Cindi ~
Powershot S2 IS
2,733 views & 0 likes for this thread, 13 members have posted to it.
2272 guests, 130 members online
