http://www.vistek.ca …tails.aspx?WebCode=217603
I have quite a few MS pro cards and I thought it might be worth while for extra memory. MS Pro are not cheaper than CF as of today.
bufferbure1 Senior Member 458 posts Joined Jul 2006 Location: Canada More info | Dec 05, 2006 01:33 | #1 http://www.vistek.ca …tails.aspx?WebCode=217603 "I collect pictures, not gears..."
ungx0013 Member 133 posts Joined Sep 2006 Location: Maplewood, MN More info | Dec 05, 2006 15:21 | #2 I would also like to know the same. I will be getting an Epson P5000 in the spring and need something like that to tranfer my photos as I take them on my Sony T9. It would be great if I could also use in on my 30D. Canon EOS 30D / 70-200mm f/2.8L IS / 24-70mm f/2.8L / 10-22mm f/3.5-4.5 / Kit Lens 18-55mm
Rellik Senior Member 720 posts Joined Sep 2006 Location: Vancouver, BC More info | Dec 05, 2006 20:39 | #3 FWIW, I have a SD to CF adapter that I've used on my XT, and it works. It does sometimes get picky if I don't have the SD card into the card all the way. I've switched to mainly using CF cards as they are so cheap now, but I'll keep it around in case I need it. -Derek 40D, 5D, 5D MK II, 1D Mark III
| Latest registered member is Mihai Bucur 971 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
