Thread started 05 Dec 2006 (Tuesday) 06:40
HELP! Shooting in a mirrored reception hall!
song4themoon
Dec 05, 2006 06:40 |  #1
Ok, in november I had this wedding in a place that seems popular for weddings and receptions. Anyway, the reception hall was pretty small for the amount of people in it, was very dark and on top of that .... had mirrors on the side walls and on the ceiling above the dance floor.
Here to get a better picture:
You walk in the door, to the right and straight are tables cramped along a mirrored wall.
Middle dance floor where above is a giant chandelie (with hardly any light on) and around that a big mirror.
To the left table for b&g including wedding party, behind them a large window front.
Next to the door, dark area for just the table with presents and a bar
It was clear that flash was needed to get proper exposed pictures, but there was the problem. Bouncing didnt work at all with the mirrors and straight on flash.. well you know about that!
I ended up going without flash most of the time and doing heavy processing to fix them but wasnt happy at all.
I have a wedding next spring int he same place and need to figure out how to do this better. Bringing strobes was my first thought.. but isnt there still the same mirror issue then?
If you say strobes.. then why and which ones do you recommend.
If anything else, please explain!!
www.forever-yesterday.com (external link)
Gear: 2 Canon 1Ds Mark II, 2 Canon EOS 20D , 580EX flash, Canon 70-200L 2.8 IS USM, Canon 17-55 2.8 IS, Canon 24-70L 2.8, CanonEF 100mm 2.8 USM, Canon EF 85mm 1.8, Canon EF 50mm 1.8, Sigma 20mm f1.8, Peleng Fisheye, 3 AB 800 w/ Pocket Wizzards
taygull
Dec 05, 2006 07:58 |  #2
Sounds like a tough one....
What I would do is see if the venue would allow me to show up and practice on afternoon or weekend. Then you could try a bunch of different things to see what would work the best.
Maybe even rent the new 50mm 1.2L...but I'm not sure when it comes out.
The other option would be to see if there is anything they can do to make the room brighter? Maybe have some portable ambient lights for the reception?
www.chrisfritchiestudi​os.com (external link)
McKinney, TX
song4themoon
Dec 05, 2006 08:00 |  #3
I have a 50mm 1.8 thats as wide I want to go in aperture anyway (even too wide).. anything wider is only good for portraits .. not for a group at the reception.
Philco
Joined Nov 2005
Dec 05, 2006 12:35 |  #4
Mirrored walls or rooms really throw off your ETTL in a bad way. I think you're only choice with your 580 is to set it to manual and shoot direct to get the right amount of light.
As for the glare, I dunno. I would treat it as if you're shooting with an off camera flash straight across from you and make sure there is something/person between you and the facing wall. I've shot a wedding on a yacht that was all mirrored panels & glass, and that's all I could do. I found myself holding my camera up and pointing it down alot as well as getting low when people where sitting so the flash didn't go past them.
Canon 5D MKIII/Canon 5D MKII/ 70-200 F2.8 IS L / 24-70 F2.8L / 85 F1.2L II/ 35 f1.4L / 135 F2.0L / Canon 600 EX-RT X 2
[SIZE=1]r follow me on Facebook. (external link)
strmrdr
Dec 05, 2006 14:13 |  #5
softbox to spread and soften the light?
a point source is going to be a headache with mirrors.
ΜΟΛΩΝ ΛΑΒΕ
tim
Light Bringer
Dec 05, 2006 17:27 |  #6
Sounds like the ideal situation for an off camera flash, with fill from the on camera flash. With all those mirrors it should trigger ok, but you might have to move it around a bit.
goforphoto
Dec 05, 2006 17:38 |  #7
You could use a couple of assistants with hand held reflectors standing just out of the shot with a couple of slave flashes fired wirelessly from floor level bouncing up to the reflectors. This should give you enough light as well as keeping the flash from reflecting back at the camera.
Just another shutterbug.
I am not a photographer, I'm an image capture technician.
Canon 40D - 70-200L f4, 28-135 IS, Nifty Fifty, 70-300 macro, 18-55 420EX Sunpak 266d
jcpoulin
Dec 05, 2006 17:54 |  #8
I am with STRMRDR, Would a flash based soft box work?
You may also "set up" a corner or different room were strobes could be set up for some guest formals and other pictures. You want to give B&G some pictures and this may be able to add to the images. At least you can control this aspect of the lighting!! You could get B&G cake shot and a lot of family/friends. Maybe work a couple different backdrops to vary background....just a thought.
1DX , 7D,16-35, 24-70 2.8II, 2.8L II, , 70-200 f2.8LII IS, 300 f2.8L IS, 500 f4 IS, 100-400L, Canon 100 2.8 macro, Canon 1.4X, 580ex, AB800X4
Canon CPS Member, PPA
www.capturingtimephoto​graphy.net (external link)
tim
Light Bringer
Dec 05, 2006 18:15 |  #9
Another simple idea might be bouncing the flash off the ceiling, using the wide panel diffuser to spread the light out a bit. I've tried using mirrors as diffusers before, they really need to be diffused if possible.
song4themoon
Dec 05, 2006 18:39 |  #10
Tim, dont forget that there is a gigantic mirror on the ceiling too. There wasnt much regular ceiling left, what was there was above the tables that were were close together.
I did try to bounce flash off the celing when I was in a area where I had a bit of it but I dont know what this was made of, but it didnt work well at all. It was too dark to really make out the color of it, I think it was an off white.. should have worked but didnt.
I am a little stressed at the thought of shooting there again in the spring
tim
Light Bringer
Dec 05, 2006 19:25 |  #11
Go in and try things out beforehand. I did mean to try bouncing the flash off the mirror on the roof with the diffuser panel of your flash down.
song4themoon
Dec 05, 2006 20:24 |  #12
thanks for the tips, I will be doing lots of reading and hopefully I can get in there to try things out at one point before the next wedding
1kerry
Dec 05, 2006 21:07 |  #13
GARY FONG lightsphere.....i will show you some pics i took from a place with MANY MIRRORS In the ceiling...not too good , but not too bad..
and the simple one...go direct with your speedlite, no bouncing, just direct...or also you can use a pocket bouncer from lumiquest, a good option.
Canon 5D MKII / Canon 60D / 35 f1.4L / 24-105 f4L IS / 15 f2.8 fishy / 28-135 f3.5-5.6 IS / 85 f1.8 / 50 f1.4 and my next lens will be a 135 F2.0L FB: https://photography-on-the.net …ead.php?t=28608​&page=1912
Wedding ­ Shooter
Dec 05, 2006 22:02 |  #14
As goforphoto said - all you need is an assistant to hold a reflecter and bounce sideways.
Chris
1,934 views & 0 likes for this thread, 9 members have posted to it.
1093 guests, 126 members online
