Torn between SD700-IS and SD800-IS.
Need help with final decision.
Thanks in advance
swoozie Hatchling 1 post Joined Dec 2006 More info | Dec 07, 2006 02:56 | #1 Torn between SD700-IS and SD800-IS.
O_T Member 209 posts Joined Feb 2006 Location: Outside of London, Ontario More info | Dec 07, 2006 09:08 | #2 I'm not familiar with either camera, but here is a link to side by side comparison if you're interested. forest fungi
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Dec 07, 2006 09:59 | #3 The megapixel difference is insignificant. The biggest differences are whether you want a longer (SD700 35-140 mm equiv.) or wider (SD800 28-105 mm equiv.) angle lens. Do you want broad sweeping vistas (SD800), or to get in close to something that's far away (SD700). The other difference is that the SD800 accepts SDHC cards which go up to 4 GB (SD700 takes regular SD cards; 2 GB), and can record TV-quality video for about 1/2 hour uninterrupted (4 GB) while the SD700 can record the same quality for only around 9 min. (1 GB) That's uninterrupted. You can always record shorter clips and splice them together later. Jon
lnknprk2005 Member 40 posts Joined Dec 2006 More info | Dec 07, 2006 14:58 | #4 isn't the sd800 equiped with the digic III ? face detection
sjprg Senior Member 297 posts Joined Jul 2003 More info | Dec 12, 2006 07:56 | #5 Yes it is, although I keep mine turned off. Also I find I should not use the flash with the High ISO setting. work great with the standard ISO. Great camera. Looks as good as my 20D, and sure a lot easire to use for casual indoor shots. Nice hiking camera also. Paul
Kyan Member 54 posts Joined Aug 2006 Location: Atlanta,GA More info | Dec 12, 2006 09:53 | #6 Swoozie,
| Latest registered member was a spammer, and banned as such! 2267 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
