Thread started 07 Dec 2006 (Thursday) 15:28
Pls help with 30D milage
shaunknee
Dec 07, 2006 15:28 |  #1
I purchased a used 30D for about half of the original cost. Cosmetically the camera is in perfect shape, side by side a new you can’t see any difference. Not even the slightest wear on the grip.
It is now at folder 909. Any ideas on activations? Remaining life.
I have 2 weeks to return it for a new body.
Thx
1DS2, 1DX, 24-70II, 70-200 2.8 IS II ,100 Macro, 1.4X, 430 EX II
RgB
Dec 07, 2006 15:34 |  #2
Folder? mine stays at 100. You mean 909 photos (actuations) The 30D is rated at 100,000 shutter actuation's:D
Daniel Speranza
30D - 580EX II
Lee ND Grad Filters---77mmWide Angle Adapter
10-22mm f/3.5-4.5 USM --- 24-70mm f/2.8L USM
Website (external link) * Flickr (external link) * Gear
Box ­ Brownie
Dec 07, 2006 15:38 |  #3
Did you use a CF card from another camera?
Canon cameras have a habit of taking the last file number from a CF used in any Canon camera.
IMHO with any new camera you should use a freshly formated CF card - formated in a card reader via the PC and then place it in the camera and format it again ready for use.
Also, to avoid confusion if you have more than one body keep your CF cards separate and allocated only to that body.
HTH maybe :)
That was a great meal ~ you must have a good set of pans :p
Images for a photographic memory (external link) | Flickr (external link) | >>>My 500px<<< (external link)
credit line is vanity, payment is sanity
shaunknee
Dec 07, 2006 16:00 |  #4
I usually use 3 CF cards. I always format them in windows, if it makes a difference.
I am using my card that I have used for the past year in my 350D.
The folder is number 909 and the image count just rolled past 9999 to 0001
The store owner told me that it had 9000 clicks.
Thanks for the responses
kitacanon
Dec 07, 2006 19:13 as a reply to  @ shaunknee's post |  #5
101-0001 is the first photo in folder #1
101-0100 is the last photo in folder #1
the counter to the left of the -
turns over when the right side of the -
begins a new 100
102-0101 is the first photo in folder #2
102-0200 is the last photo in folder #2
103-0201 is the first photo in folder #3
109-1000 is the last photo in folder #9
110-1001 is the first photo in folder #10
each folder contains 100 photos/actuations
123-xxxx = 2,3xx photos
223-xxxx = 123 folders (remember the first column began at 1) = 12,3xx photos
929-xxxx = 829 folders = 82,9xxx photos/actuations
I think...
My Canon kit 450D/s90; Canon lenses 18-55 IS, 70-210/3.5-4.5....Nikon kit: D610; 28-105/3.5-4.5, 75-300/4.5-5.6 AF, 50/1.8D Nikkors, Tamron 80-210; MF Nikkors: 50/2K, 50/1.4 AI-S, 50/1.8 SeriesE, 60/2.8 Micro Nikkor (AF locked), 85mm/1.8K-AI, 105/2.5 AIS/P.C, 135/2.8K/Q.C, 180/2.8 ED, 200/4Q/AIS, 300/4.5H-AI, ++ Tamron 70-210/3.8-4, Vivitar/Kiron 28/2, ser.1 70-210/3.5, ser.1 28-90; Vivitar/Komine and Samyang 28/2.8; 35mm Nikon F/FM/FE2, Rebel 2K...HTC RE UWA camera
Box ­ Brownie
Dec 07, 2006 19:31 |  #6
Hmmm!!!
My 350D is up to folder 181 currently image number 8151
I seems to me that based on the CF folder count that the camera has over 90,000 images taken on it. The MTBF for the 30D shutter AFAIK is 100,000
So, if the calculations and assumptions (i.e. that the camera folder count has never been reset and you used a PC formated card the very first time you inserted one in the 30D so that it took up the camera 'data') are correct that 30D has had a lot of hard usage in its relatively short life.
If it were me I would not be buying it!
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Dec 07, 2006 19:47 |  #7
Mind you, even if the buyer has to replace the shutter soon he/she will still come out ahead if they paid half price for it so long as nothing else breaks...
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
rbush83
Dec 07, 2006 20:11 |  #8
The only true way to know the shutter activations if for canon to check it themselves with their service software.
Anything else really is guesswork. The file numbering system is a poor way to judge except by people who have owned the camera since new and take steps to keep the numbering consecutive.
I don't think it's worth going back and paying double when the shutter probably won't fail before you're ready to off it. How many shots do you average? Even if the shutter does fail down the road, it's replaceable for $160-200 i believe.
Just as a point I was messing around in the menus and clicked the manual number reset and the camera than went to the next folder number. On a 30D a folder is 10,000 images. So did I just mis-click in the menu, or add 10,000 actuations ;)
It's unfortunate that Canon hides this information.
30D etc.
kitacanon
Dec 07, 2006 20:20 as a reply to  @ rbush83's post |  #9
I just emailed canon for verification of my calculations...
rbush83
Dec 07, 2006 20:31 |  #10
There is nothing wrong with your math. The problem is your math is based on something file numbering system isn't designed to keep track of. It is very easy to change the file numbering.
The only way to know actuations for certain is for canon to extract it with their service software.
30D etc.
JMHPhotography
Dec 07, 2006 20:46 |  #11
To be honest... the 30D has the capability of manual reset of the folders... so conceivably one could hit the manual reset 900 times and end up with 900 folders. I haven't tried it myself, but I'm thinking you can do this without ever snapping the shutter. So trying to determine how many accuations using this is a bit of a crap shoot.
~John
(aka forkball)
Have a peek into my Gearbag. and My flickr (external link)
editing of my photos by permission only. Thanks
shaunknee
Dec 07, 2006 21:04 as a reply to  @ JMHPhotography's post |  #12
Lets say Kitacanon is correct in his math don't you think the camera would show some signs of wear ? Maybe on the grip or trigger ?
Regardless I have a couple of weeks to decide.
kitacanon
Dec 07, 2006 21:55 as a reply to  @ shaunknee's post |  #13
from Canon...
Thank you for contacting Canon product support. We value you as a Canon
customer and appreciate the opportunity to assist you with your file
numbering and registration inquiry.
Yes, a new folder is created after 99 images are captured in one folder.
We hope this information is helpful to you. Please feel free to contact
us again if you have any other questions or concerns with the EOS 10D.
Thank you for choosing Canon.
Sincerely,
Jason
Technical Support Representative
JMHPhotography
Dec 07, 2006 22:03 |  #14
kitacanon wrote in post #2369433 (external link)
from Canon...
Sincerely,
Jason
for the 20D this is true... for the 30D this is NOT true
~John
(aka forkball)
kitacanon
Dec 07, 2006 22:10 |  #15
forkball wrote in post #2369457 (external link)
Sorry for the confusion...I guess if the file size is 999 rather than 99, then 909- would be about 8+K actuations...
Enjoy your new cam....
2,341 views & 0 likes for this thread, 14 members have posted to it.
2487 guests, 103 members online
