Do Canon make a slide copier ??
Is there a slide copier compatable with a 30D ??
thanks
Dilligaf Member 87 posts Joined Dec 2006 Location: Cornwall England More info | Dec 08, 2006 10:02 | #1 Do Canon make a slide copier ?? Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
Dchemist Goldmember 1,632 posts Joined Sep 2003 Location: Woodbury, Connecticut More info | Dec 08, 2006 12:16 | #2 Assuming you want to make a digital copy, you can buy slide scanners that specifically do this but I did not see any Canon gear. I have done this with my Epson flat bed scanner which has a 35 mm holder and back light. Results were good enough. Here is the link to B&H: POTN Book Vol4 Astronomy Image Manager and BC Member
Thanks, I actually meant a gizmo that is used on camera, as all my money went on the 30D, I was going to buy a filmscanner but only have about 600 slides, and it would sit idle after archiving them as I am into Digital pictures now Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Dec 08, 2006 13:04 | #4 They used to in the Good Old Days (it was an add-on for the macro and bellows). But on-camera slide copiers are all set up for film-to-film operation, and work at a fixed 1:1 ratio or actually allow you to zoom in. You'd only get part of your slide/negative with the 30D that way. If you buy the scanner, you can always sell it when you've finished all your slides. Jon
chrismaddock Senior Member 307 posts Joined Mar 2002 Location: Southampton, UK More info | Dec 08, 2006 13:08 | #5 Ohnar now make slide copiers for crop sensor cameras - mount on the camera instead of the lens, slip the slide in the other end, zoom to crop if desired, point at an even light source and take the shot. Chris Maddock
aussieskier just that stupid? 10,608 posts Joined Aug 2005 More info | Dec 08, 2006 13:13 | #6 Photosguy has a post about one that he cobbled together. I have been looking to make one, just haven't had time with college... waiting for the break. Anyways, check out the post if your into the DIY thing.
Thanks for the input, will check out the options you have mentioned. Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
YosemiteJunkie Goldmember 1,339 posts Likes: 1 Joined Jul 2005 Location: Carrollton, GA More info | Dec 09, 2006 02:48 | #8 Here you go. I think this is what you might be looking for. Happy Shooting, Herb
Perfect, thank you Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Dec 09, 2006 05:31 | #10 The problem with a slide copier has always been the light source to use. That's why I went with the Canon FS4000 film/slide scanner. Skip Douglas
love one, but alas all me money has gone aquiring the 30D Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
ScottE Goldmember 3,179 posts Likes: 3 Joined Oct 2004 Location: Kelowna, Canada More info | Dec 09, 2006 11:24 | #12 I used to improvise a slide copier by putting my light table on the floor and setting up a tripod with camera and macro lens over it. The results were good enough for web display, but if I wanted to make a print I would still have it professionally scanned.
Dec 09, 2006 11:32 | #13 ScottE wrote in post #2376444 However, I found I was using the light table so little since I went digitial that it is now on the bottom of a pile in my storage shed. I will have it Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
Turbowolf Senior Member 540 posts Likes: 1 Joined Dec 2004 Location: Olympia, WA (TESC) More info | Dec 09, 2006 11:42 | #14 You might want to check out your local college campus. Many, like mine, allow community members to use their equipment. It's a simple alternative and an easy way to get access to a high quality, dedicated slide scanner. Dave
excellent idea, will look into that on Monday. Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
| Latest registered member is ANebinger 997 guests, 178 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
