Thread started 08 Dec 2006 (Friday) 20:29
Fill in Flash on Xti
ChrisBlaze
Dec 08, 2006 20:29 |  #1
How do you use it with the pop-up flash, where is it in the menu?
Canon 1D Mark II N/5D Mark III/ 6D/ 7D /85mm f1.2L Mk1/ 24-70 f2.8L/ 70-200mm f2.8L IS USM/ 100mm Macro f/2.8
Honolulu POTN
stupot
Dec 08, 2006 20:32 |  #2
shoot in Av mode and it will act as fill. (is it the same for tv mode? im not sure...)
Canon EOS 350D, Sigma 10-20 f4-5.6, 24-105 f4L IS, 70-200 f4L, 300 f4L IS, Kenko 1.4x pro300, 430EX, Apple Powerbook G4
Free filters for your flashgun!
ChrisBlaze
Dec 08, 2006 20:35 |  #3
werid that what I was doing, just didnt seem to work too well.
Honolulu POTN
Adam ­ B.
Dec 08, 2006 21:14 |  #4
The flash must be "popped up" in order to be used as fill. Push the button near the flash with the little lightning bolt.
Adam
"For me, it is far better to grasp the universe as it is than to persist in delusion, however satisfying and reassuring." Carl Sagan - The Demon-Haunted World
ChrisBlaze
Dec 08, 2006 22:01 |  #5
Adam B. wrote in post #2374011 (external link)
yea I did but it totally blew out the picture.
Honolulu POTN
bufferbure1
Dec 08, 2006 22:10 |  #6
ChrisBlaze wrote in post #2374231 (external link)
While u are in Av mode, u should lower the flash compensation. Use the * button to lock the flash explosure first, and then shoot.
"I collect pictures, not gears..."
Lenscode:1635.1785.50f​18.100Macro.70200F4IS.​580EX.30D.5D2
ChrisBlaze
Dec 08, 2006 22:12 |  #7
ahh I will try that next time.
Honolulu POTN
tange1
Dec 09, 2006 12:24 |  #8
bufferbure1 wrote in post #2374277 (external link)
Could you explain what you mean by this? Meter the shot, hit the * then shoot? What does this do? I often find my xti flash shots to be a bit over done.
Canon Rebel Xti, EF-S 18-55mm kit lens
EF 28-135mm f.3.5-5.6 IS
50mm f/1.8
Battery Grip
430ex ii
basroil
Dec 09, 2006 12:53 |  #9
best thing to do, adjust the flash level in the first menu of your camera, set it to -2ev and you are set
tsaraleksi
Dec 09, 2006 15:32 |  #10
Perhaps what happened was that you tried to shoot in Av mode with an f/stop that required a shutter speed above 1/250, meaning that it badly overexposed the shot, because the flash can't sync at speeds faster than that.
--Alex Editorial Portfolio (external link)
|| Elan 7ne+BG ||5D mk. II ||1D mk. II N || EF 17-40 F4L ||EF 24-70 F2.8L||EF 35 1.4L || EF 85 1.2L ||EF 70-200 2.8L|| EF 300 4L IS[on loan]| |Speedlite 580EX || Nikon Coolscan IV ED||
steved110
Dec 09, 2006 17:25 |  #11
tsaraleksi wrote in post #2377095 (external link)
that's the most likely explanation.
The easiest way to use flash, fill or otherwise, on an Eos Camera is in P mode. It truly does become plug'n play then. worry about fancy stuff when you have a better handle on it. but for pop-up fill flash, this works best. anything more serious, you need a speedlite anyways.
Check out the stickies on the flash/ accessories forum to get more detail
this link is useful for advice on how eos flash works:
http://photonotes.org/​articles/eos-flash/ (external link)
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
1,727 views & 0 likes for this thread, 8 members have posted to it.
2452 guests, 101 members online
