Thread started 10 Dec 2006 (Sunday) 10:18
Fossil
alexf
Dec 10, 2006 10:18 |  #1
Here's a fossil I found on a beach in southern England last month. It's just a bit bigger than my thumb! c&c welcome
ALexF
Canon 20d, 40d, Canon 400mm L F5.6, Canon 70-200 L IS 2.8, Canon 17-85 IS, 1.4ex, Sigma macro 105 dg, 580 ex, Gitzo GT3530s, Markins M20 head and more;)
http://www.alexfrs.blo​gspot.com/ (external link)
Kraig ­ C
Dec 10, 2006 10:22 |  #2
Thats amazing!have you had the material looked into, it looks like the shell material has been completely replaced with pyrite!
alexf
Dec 10, 2006 10:25 as a reply to  @ Kraig C's post |  #3
no i havent but it is from the jurassic coastline. I brushed it gently in cold water and removed the clay which then revealed the golden look. It gets a bit addictive once you find something like this, you can spend hours searching along the coast .
ALexF
nitefrogger
Dec 10, 2006 10:27 |  #4
Kraig C wrote in post #2380297 (external link)
Looks like small ammonites. We get pyritized fossils around here occasionally. They do have that brassy look of pyrite. Interesting subject.
LordV
Dec 10, 2006 10:42 |  #5
Great shot- amazing fossil :)
Brian V.
Macro Hints and tips
Kraig ­ C
Dec 10, 2006 10:55 |  #6
Ammonites and other invertebrates are the most common fossil replaced with Pyrite, in this form it's referred to as Marcasite, due to the lower temperature that it replaces the host.
alexf
Dec 10, 2006 11:02 as a reply to  @ Kraig C's post |  #7
is that similar to fools gold?
ALexF
nitefrogger
Dec 10, 2006 11:04 |  #8
alexf wrote in post #2380436 (external link)
same mineral
alexf
Dec 10, 2006 11:29 as a reply to  @ nitefrogger's post |  #9
ok thanks. I also found this, any ideas?
ALexF
Kraig ­ C
Dec 10, 2006 11:36 |  #10
So, from a mineral collector's notes about this material in fossil replacement etc, "it quickly degraded into an oxide and releases a sulfuric acid gas that attacks papers and boxes that contain specimens so, to prevent ruining other specimines, containers and lables, keep it in sealed in archival quality plastic container. When opening large specimines of marcasite for handling, open them a well ventilated area to avoid succoming to sulfur dioxide gases that may have built up over time. Another thing people have suggested is there may be an anearobic reaction taking place by ancient bacteria, they suggest to preserve the mineral, steralize it with lysol about as often as you dust off your other specimines to reduce the amount of deterioration.
alexf
Dec 10, 2006 11:43 as a reply to  @ Kraig C's post |  #11
wow thanks. I have read somewhere that I caould also coat it with PVA glue ( a type of sealant used on walls etc). Do you know what thw amber coloured crystal type stone above is? That measures approx 6 inches across
ALexF
Kraig ­ C
Dec 10, 2006 12:01 |  #12
hard to tell, some small crystals form in blankets between fissures in rocks, it's could be a calcite mineral.
alexf
Dec 10, 2006 12:17 as a reply to  @ Kraig C's post |  #13
i can see formations in cracks in the rock, not sure if this bigger piece helps more?
ALexF
JenzZx2
Joined Feb 2006
Dec 10, 2006 15:18 |  #14
Awesome, love the first one.
We were just there in June.. but the fossils we found weren't nearly as cool as that.
-Jen
http://jenwhite.smugmu​g.com (external link)
5D, 30D, 24-70 f/2.8L ,70-200 f/4L, 17-40 f/4L, 50mm f/1.8 II, 100mm f/2.8 Macro, 580EX, ABR800, AB400.
uttershutternut
Dec 14, 2006 21:22 |  #15
ammonites, right? gorgeous!
Mircales happen every second of our lives. You just have to be aware enough to see them.
Canon S3 IS Raynox 250 macro lens
http://corazondedios.d​eviantart.com (external link)
2,597 views & 0 likes for this thread, 6 members have posted to it.
Fossil
863 guests, 133 members online
