Thread started 10 Dec 2006 (Sunday) 19:55
Can't set f-stop on 20D
jboyd
Joined Mar 2003
Dec 10, 2006 19:55 |  #1
Has anyone else had this problem? I haven't used my 20D for a few days, and I tried to take a pic this evening of my new puppy to use for a Christmas card. Set the camera on Manual, set shutter speed, and aperature just stays at 4.0. I put on a different lens - the 85 1.8, and aperature reads 00. (I started with the 17-40 2.8) I put on the nifty 50 it reads 4.0 again. And of course the camera is just out of the warranty period.
Jackie Boyd
Jackie Boyd
40D | 20D | 10D | 16-35 f/2.8L | 24-70 f/2.8L | 70-200 f/4L | 85 f/1.8 | 50 f/1.8 | Tamron 90 f/2.8macro | Tamron 28-75 f/2.8 XR Di LD | 550EX | AlienBee 800's | and too many other accessories!
Ves
Dec 10, 2006 20:03 |  #2
I'm guessing you know the main dial in the back is used to change the aperture value in 'M' mode?
liza
Dec 10, 2006 20:05 |  #3
And make sure the "on" switch is set to the topmost setting. If you don't put it there, the command dial is disabled in M.
Elizabeth
Blog
http://www.emc2foto.bl​ogspot.com/ (external link)
cdifoto
Don't get pissy with me
Dec 10, 2006 20:09 |  #4
liza wrote in post #2382208 (external link)
This is what I was going to suggest.
Sledhed
Joined Jun 2005
Dec 10, 2006 20:25 |  #5
I do that ALL the time.
Chris
Gear List | Website (external link) | Sports Sample Pictures (external link) | Four Seam Images (external link)
If you’re good at something, never do it for free. - The Joker
jboyd
Joined Mar 2003
Dec 10, 2006 20:29 |  #6
yup, I know about the suggestions above, and checked all of that initially, before posting here. Still doesn't work.
Jackie Boyd
Wilt
Dec 10, 2006 20:35 |  #7
Have you checked the contacts on the lens mount, to make sure there is not debris that prevents proper connection? The 00 is an indication of no lens (such as using my Olmpus lens on EF mount adapter).
jboyd
Joined Mar 2003
Dec 10, 2006 20:51 |  #8
checked the contacts. All look clean. BTW, if I put the camera in aperature mode I *can* change the aperature.
Jackie Boyd
liza
Dec 10, 2006 20:54 |  #9
Remove the battery, replace it, and turn the camera on again to the second ON setting. Then try once again. It may need to be rebooted.
Elizabeth
Blog
jboyd
Joined Mar 2003
Dec 10, 2006 21:19 |  #10
Thanks Liza - did that. It didn't change anything. I then tried my last resort and "reset all camera functions." That worked. I don't know what I possibly could have set that would have not allowed me to set the aperature. I think I will still call Canon support tomorrow.
Thanks everyone for your help!
Jackie
Jackie Boyd
Ves
Dec 10, 2006 21:26 |  #11
Isn't there a custom function that makes it so the back wheel selects AF points rather than aperture?
jboyd
Joined Mar 2003
Dec 10, 2006 21:29 |  #12
I know there is one to use the wheel to select focus point, but I am not aware if that also makes it not set aperature. I did have it set to use the wheel to select focus point. Back to the manual!
Jackie Boyd
Wilt
Dec 10, 2006 23:24 |  #13
jboyd wrote in post #2382384 (external link)
You are not putting the power switch into the THIRD setting (the line above the word 'On')!
If you put the power switch to On, even in Manual mode only the wheel near the shutter button works. On only way for the big wheel on the back to work (to control the aperture) is when the Power button points to the Line!
jboyd
Joined Mar 2003
Dec 10, 2006 23:39 |  #14
Wilt wrote in post #2382930 (external link)
I did have the setting to the line above "on" and it still didn't work. That was one of the first things I checked.
Jackie Boyd
basroil
Dec 10, 2006 23:58 |  #15
this looks like a simple case of broken/dirty lens, OR, if all lenses do that, a simple case of i was too lazy to turn off the camera while changing lenses. if it's just the 85 that does it (which you can check with your second body, the 10d), then it's the lens that needs fixing, else, most likely some small firmware glitch that can probably be fixed simply by re-installing the firmware
7,907 views & 0 likes for this thread, 12 members have posted to it.
1494 guests, 159 members online
