Thread started 11 Dec 2006 (Monday) 10:22
Finally took my 580EX outside experimenting with Fill Flash
TMR ­ Design
Joined Feb 2006
Dec 11, 2006 10:22 |  #1
Well, I finally got out this weekend to shoot a bit and I decided to use my 580EX and explore fill flash a bit. I can't believe I waited this long. I went to a park I go to often and took some shots in places that I know have a lot of trees and shade where I have had trouble getting great exposure across the whole dynamic range. There's one spot near a rock bridge where there are ducks and rocks and typically when I get the duck looking white the water and reflections in the water are dark. There isn't much that I could bounce the flash off so I brought my white bounce card and gave it a try.
I'm very pleased with the results and if I took these same pictures without the flash I would have very dark areas and no highlights in the rocks and water.
Robert
jjmucker
Dec 11, 2006 10:27 |  #2
good shots there. so can you notice a big difference from when you went to the same spot without the flash.
its something i haven't done yet with my 430ex. i will need to get out more with the speedlight :D
5D3 x 2,5DII,30D,15,24,50,85​,100,24-70,70-200.
Website :
Glasgow Wedding - Portrait Photographer (external link)
TMR ­ Design
Joined Feb 2006
Dec 11, 2006 10:30 |  #3
jjmucker wrote in post #2384549 (external link)
Huge difference!! The second shot would have very dark rocks normally. Now I understand why many people don't go anywhere without their flash. Even when you don't think you need one it can really help.
Robert
jjmucker
Dec 11, 2006 10:31 as a reply to  @ TMR Design's post |  #4
how far were you from these ducks. did you just shoot in AV mode and resume normal operation :D
Website :
TMR ­ Design
Joined Feb 2006
Dec 11, 2006 10:44 |  #5
jjmucker wrote in post #2384566 (external link)
I was about 20 feet away in both shots using my 85mm f/1.8 lens. I find that I hardly ever shoot in Av mode and have really taken a liking to shooting in Manual mode. I like the control it gives me. For those shots I was at 1/250s (max sync speed with flash), F/11, ISO 400, no EC, +1/3 FEC. Using these settings I was able to just focus and shoot without having to make changes and I let the flash do its work.
Robert
jjmucker
Dec 11, 2006 11:05 as a reply to  @ TMR Design's post |  #6
when you say shooting in manual, do you mean on the actual speedlight or the camera. ive never tried using manual on the speedlight but always shoot in manual with my 350D as i feel more comfortable using this setting now
Website :
TMR ­ Design
Joined Feb 2006
Dec 11, 2006 11:08 |  #7
jjmucker wrote in post #2384683 (external link)
Sorry I was not clear. Since you were speaking of Av mode and referring to the mode of the camera I was doing the same. I shot those with the camera in Manual but the flash on ETTL.
Robert
Heatseeker99
Dec 11, 2006 11:13 |  #8
This is a great post. I brokedown and ordered a 430EX over the weekend for use as fill flash, and to exploit the benefits of bouncing flash. I have always been an "available light" guy, trying to avoid the flash look. After reading this section lately, I know that with proper technique, it isn't so obvious.
A.J.
1D mkIII \ 24-105L \70-200 2.8IS II \ 35L \ 85 1.8 \ Kenko 1.4x \ 580EXII \ 430EX + every piece of Nikon/Photogenic equipment imaginable at the studio.
TMR ­ Design
Joined Feb 2006
Dec 11, 2006 11:16 |  #9
Heatseeker99 wrote in post #2384715 (external link)
You hit the nail on the head. I've learned that understanding the equipment and some theory has helped me tremendously. I shoot a lot in daylight and it never occured to me to use a flash outside until I started reading and researching and grasping the concept of fill flash. If used correctly the flash is one of the most valuable pieces of gear I own.
Robert
jjmucker
Dec 11, 2006 11:18 as a reply to  @ Heatseeker99's post |  #10
thats ok TMR design. i should have realised you were talking about the camera just wanted to be sure :D
Heatseeker99, you will enjoy your new speedlight. as much as i love available light, sometimes you just need a speedlight, and as you said, using the right technique it will not look obvious at all that you have used flash
Website :
TMR ­ Design
Joined Feb 2006
Dec 11, 2006 11:19 as a reply to  @ TMR Design's post |  #11
Another shot from the same location. If I didn't have the flash the water would not look blue as it does and the rock in the bottom right would be dark with no highlights. The darker rock behind it would appear black with no hightlights whatsoever.
Robert
Wilt
Dec 11, 2006 11:29 |  #12
Just some observations for the benefit of those who are motivated by Robert's photos to try flash fill...
Robert used a 580EX to provide fill at f/11 to subjects 20' away...he was MAX'd out in the power output from that flash! If you use a lesser flash, you will not be able to use fill flash to the same distances. And if you think you can open up the lens to make it easier on the flash, remember that he was at 1/250...so going to higher shutter speed for proper exposure with larger aperture would force the use of HSS, but that causes the flash's light output to drop very precipitously!
So set your expectations accordingly, with lesser output flash units!
TMR ­ Design
Joined Feb 2006
Dec 11, 2006 11:34 |  #13
Wilt wrote in post #2384784 (external link)
Robert used a 580EX to provide fill at f/11 to subjects 20' away...he was MAX'd out in the power output from that flash! If you use a lesser flash, you will not be able to use fill flash to the same distances. And if you think you can open up the lens to make it easier on the flash, remember that he was at 1/250...so going to higher shutter speed for proper exposure with larger aperture would force the use of HSS, but that causes the flash's light output to drop very preciptously!
Thanks for adding that Wilt. I do take the power of the 580EX for granted. It's quite a flash.
Robert
Heatseeker99
Dec 11, 2006 11:46 |  #14
obv.
A.J.
Wilt
Dec 11, 2006 11:49 |  #15
Heatseeker99 wrote in post #2384869 (external link)
obv.
Obvious only to those who know the 580EX was maxed out. It takes an understanding of Guide Numbers to realize that fact, and with increasing dependence on ETTL tens of thousands have no clue what Guide Number is and how it can be useful!
5,572 views & 0 likes for this thread, 7 members have posted to it.
2876 guests, 152 members online
