As the title says I need an L plate for my 1D mark II n. I just bought a markins m10 ballhead and a Really Right Stuff quick release lever clamp to make it downright perfect. The only thing I'm stuck on, is which L-plate I should get for it. I bought the RRS L plate for my 5D because it looks gorgeous and should be perfectly compatible with my RRS clamp but deciding which one for the 1D2n has proved a little harder.
RRS says on their website that some Kirk plates will work with their clamps. The RRS 1D2N L plate (http://reallyrightstuff.com/body_plates/canon/index.html
then click on the 1d2n on the right) apparantly has to be loosened and moved approximately 1 cm in order to fit the shutter release cable in the camera with the L plate mounted and camera attached in portrait mode (vertical orientation). I don't see anything about that on the Kirk L plate page (http://kirkphoto.com/lbracketsc.html
1) Does anyone know if the Kirk plate can do this without having to shift the plate?
2) Does anyone know if the Kirk plate will even fit in the RRS clamps?
thanks!
