Thread started 11 Dec 2006 (Monday) 19:20
What filters are bettermainly for protection?
RgB
Dec 11, 2006 19:20 |  #1
For the 16-35L and 70-200 2.8LIS which protection filter is better.
UV or Skylight?
Which would have other benefits?
Daniel Speranza
30D - 580EX II
Lee ND Grad Filters---77mmWide Angle Adapter
10-22mm f/3.5-4.5 USM --- 24-70mm f/2.8L USM
Website (external link) * Flickr (external link) * Gear
Bill ­ Roberts
revolting peasant
Dec 11, 2006 19:23 |  #2
UV. I'd recommend either Heliopan or B+W. Skylight will do pretty much the same but add a very slight warmth to the colour. Now I'm putting on the flak jacket waiting for the anti-filter brigade to arrive :lol: :lol:
cheers
Bill
BiLL
RgB
Dec 11, 2006 19:47 |  #3
Bill Roberts wrote in post #2386660 (external link)
cheers
Bill
That's what i quoted for:D
Daniel Speranza
30D - 580EX II
RgB
Dec 11, 2006 19:49 |  #4
I am getting these.
Hoya 77mm UV(0) (Ultra Violet) Multi Coated Ultra Thin Glass Filter
Hoya 77mm UV(0) (Ultra Violet) Multi Coated Glass Filter
Daniel Speranza
30D - 580EX II
Hermeto
Dec 11, 2006 19:56 as a reply to  @ RgB's post |  #5
Good luck with cleaning them!
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Dec 11, 2006 21:36 |  #6
sounds good, but remember, a thin filter will not let you put a lens cap on it as it's thread where the cap attaches is missing or too thin.
Gallery: http://tomyi.smugmug.c​om/ (external link)
Glenn ­ NK
Dec 11, 2006 21:44 |  #7
I use a B + W UV filter - it's not cheap, but it's one of the best made. It is an "F-PRO", and it cost me almost $100 Cad - about 1/15th of the cost of my lens.
It is thin, and the Canon lens cap will fit on it with no problem.
It can be cleaned - mine has been cleaned several times - with a little "breath moisture" and a soft cotton cloth. I have lens tissues, but they are nuisance to use.
When did voluptuous become voluminous?
RgB
Dec 11, 2006 21:56 |  #8
Hermeto wrote in post #2386783 (external link)
Ill be using Copper Hill Ultimate D-SLR Care Kit solution designed specially for Multi coated filters or lenses.
http://www.qualitycame​ra.com.au …cPath=33&produc​ts_id=1352 (external link)
"Introducing... The Lens Care Kit
PSI's Eclipse is the absolute best chemical to use in cleaning an imaging sensor. However, it does not work quite as well on lenses and filters. Because of the multi-coatings of the glass, it has a tendency to leave a residue. That's why I am now offering you the absolute best chemical to use on lenses and filters - Formula MC (standing for multi-coating). Together, with the lens tissue, cloth and a top notch retractable lens brush, this is the only Lens Care Kit you'll ever need to buy. It's all put together in a plastic tube carrying case that you just toss into your camera bag. I've used quite a few different micro-fibre cloths over the years, but this one is without a doubt the BEST lens cloth of them all - you will love it! The pick-up ability gets better with each washing."
Daniel Speranza
30D - 580EX II
Hermeto
Dec 11, 2006 22:37 as a reply to  @ RgB's post |  #9
I use the same thing, it was included in the kit I just recently ordered from Copper Hill.
However, I do not have first hand experience, but I read more than once that Hoya filters, although optically excellent, can be real pain in the but when it comes to cleaning.
Seems that only Hoya Pro 1 series doesn’t suffer from that problem.
I’ll try to find more info on that subject..
RgB
Dec 12, 2006 02:02 |  #10
Hermeto wrote in post #2387381 (external link)
Thanks HERMETO
Daniel Speranza
30D - 580EX II
tiktaalik
Joined Feb 2006
Dec 12, 2006 06:17 |  #11
Oh yes, we horrible anti-filter people lurking around to destroy all that's holy... :rolleyes:
Here's the other side: Use a lens hood for protection. Front elements are a lot tougher today than in the past and do not get damaged from cleaning. In a harsh environment, like hard blowing sand or blowing sea spray, a filter is a good thing to use. I'd recommend the Hoya digital filter - it's not UV or skylight, just a well-made piece of glass designed to protect the lens.
Julie
My galleries (external link)
https://photography-on-the.net …hp?p=1330884&po​stcount=56
Duncaji
Dec 12, 2006 06:36 |  #12
tiktaalik wrote in post #2388478 (external link)
I'd like to add a question to this.......does having a protective filter on affect the image in terms of sharpness? I'm at the moment experimenting with and without a filter..........and agree that the lens hood is a dual purpose tool.........keep unwanted light out and protects the lens !
Thoughts ?
....."the photographer must have, and keep in him, some of the receptiveness of the child who looks at the world for the first time, or the traveller who enters a strange country"....Bill Brandt
tiktaalik
Joined Feb 2006
Dec 12, 2006 06:55 |  #13
Duncaji wrote in post #2388506 (external link)
Thoughts ?
Yes a filter can have a negative effect on sharpness especially if it's a cheaper filter. Some lenses seem more prone to this problem than others. A filter can also introduce flare and reflections when used under low light conditions with light sources in or near the field of view.
Definitely compare your images with and without the filter and include some night shots as well!
Julie
canoflan
Dec 12, 2006 07:53 |  #14
RgB wrote in post #2386649 (external link)
UV or Skylight?
Unless you are going to use the filter for the effect, I wouldn't use it except when you are storing and traveling with the camera. I don't use filters unless I need the effect.I heard elsewhere on this forum that why buy "L" glass and put poor glass on the front. I just exercise great care with the lens cover and hold the lens pointed down when not shooting between shots.I mainly use the lens hoods for protection if I really feel I need it.If you plan to use these for "while shooting protection," I suggest you save your money for more L lenses.
Bill ­ Roberts
revolting peasant
Dec 12, 2006 12:31 |  #15
To be fair ANY filter will degrade the image. I don't think that there can be any logical argument against that, the argument comes about whether the degradation can be seen in real life terms. I'm certain it can be measured but given a top quality filter, in the vast majority of shots I can't see any difference at all. Yes there are instances that they can cause flare when a bright light source is in the frame, but the easy answer to that is remove the filter for that particular series of shots. I'm always in favour of using a lens hood for all my lenses.
I'm not sure I've ever seen a poll about just how we're split on this but I'd guess around 50/50? I've seen LOTS of threads on the subject and I really do try and resist joining in but my sense of humour usually gets the better of my common sense in the end :) I firmly subscribe to the "only take it off if it's causing a problem" camp because I'd rather clean a filter than my front element. I don't have any issue at all with anyone who has the completely opposite point view though, but I do reserve the right to poke fun at them :p
and would expect nothing else in return!
cheers
Bill
BiLL
2,672 views & 0 likes for this thread, 11 members have posted to it.
2189 guests, 138 members online
