Thread started 12 Dec 2006 (Tuesday) 13:14
Grad ND Filters
Stime187
Dec 12, 2006 13:14 |  #1
I'm in the market for one (maybe some?) Grad ND filters and I'd like a little insight from those that already own them and probably know more than me...
Anyways, I'm only going to start with one (can't afford to buy a set at this point, poor college student) and my first question is which one do you guys/gals use the most? I'm between the .6 and .9 (2-stops vs. 3) right now, so I just thought I'd see what opinions people have here.
Besides that, I'm looking at the Tiffen filters on BH for around $75 each. Problem is, I don't think thats what I want... wouldn't the square ones with a screw-on type holder give me more control over the "line" would line up? If I wanted to turn it at an angle or something of that nature, no?
Please just post your thoughts, I appreciate any help.
- Scott
Galleries, Workshops, etc - LightOfTheWild.com (external link) | Become a Fan -- Facebook.com/LightOfTh​eWild (external link) | On Twitter -- @LightOfTheWild (external link)
foxbat
Joined Jan 2005
Dec 13, 2006 03:51 |  #2
Stime187 wrote in post #2389796 (external link)
That's right, you need a square filter system unless you plan to only take photos of scenes where the line is across the center of the frame. Given your financial situation a Cokin P system might be the way to start. When you get more cash you can start to use high quality Singh-Ray filters in the Cokin mount.
Andy Brown; South-east England. Canon, Sigma, Leica, Zeiss all on Canon DSLRs. My hacking blog (external link).
Tsmith
Formerly known as Bluedog_XT
Dec 13, 2006 06:59 |  #3
Heres my setup: https://photography-on-the.net …php?p=1216803&p​ostcount=7
Stime187
Dec 19, 2006 12:14 |  #4
Thanks Bluedog, can you still use a polarizer with that setup?
And I assume you use it on the 17-40 L? So its fine at the 17mm end?
- Scott
Mike ­ K
Joined Apr 2001
Dec 20, 2006 11:01 |  #5
I use the HiTech from this source:
http://www.2filter.com​/prices/htpackages.htm​l (external link)
It comes with one adapter ring (it helps if most of the lenses you want to use have the same filter size), Cokin filter holder, and one ND grad filter. I suggest using a .6 hard and .9 soft. 2filter is a very reliable, small retailer. give them a call.
Mike K
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
sjafari
Dec 20, 2006 11:59 |  #6
This is a bit more expensive than the Cokin P system, but the Lee filters have treated me very well so far. The Grad NDs are 4*6", and are on a ring that rotates to allow for a good deal of control for where the line is placed. I can also have the CPL and grad ND attached without any issues. I have a .6 soft and .6 hard, but am now also considering getting a .9 soft (the .6 is not enough for bright skys). For the price though, i have only heard good things about the cokin system
-Shehab-
http://www.fotojafari.​net (external link)
5Dii, 16-35/2.8ii, 24-70/2.8, 135/2
halfmoonray
Dec 20, 2006 21:56 |  #7
I have the .6 Lee filter and I like it very much but am thinking of the .9 because it's darker for bright skies as sjafari says... I would start with a .9
85 f/1.2L II
100 f/2.8 macro
MPE-65 f/2.8
jfrancho
Dec 20, 2006 22:11 |  #8
I started with Cokin "P" sytem, and have since switched to Hitech square resin filters that fit in the Cokin holder. I have several flavors, as well as a .6 and 1.2 standard ND filters. Cokin makes a starter kit with a a holder, adapter, and .6 "Soft Grad Gray" that served me well for <$50.
Tsmith
Dec 21, 2006 12:03 |  #9
Stime187 wrote in post #2420451 (external link)
- Scott
Your welcome _ Yes and 17mm works fine.
Stime187
Dec 25, 2006 20:24 |  #10
Okay, I'm going to go with Bluedog's setup... now my question is... which should I get first .6 or .9? What do you guys use the most?
I intend to get the soft version either way.
- Scott
Tsmith
Dec 25, 2006 20:49 |  #11
Scott I use the 0.6 - 2 stop soft edge the most of all and generally thats the strength most recommended to start off with if only purchasing the one.
Used the 0.6 with the Canon EF-S 10-22mm at 10mm in this shot and you can kinda tell the transition line in the photo.
2,134 views & 0 likes for this thread, 7 members have posted to it.
Grad ND Filters
2130 guests, 130 members online
