I have the anti twist plates for the 488 RC2 and lost one of the bolts and busings from the plate. Anyone know where you can get these parts where it makes sense, rather than just buying a new one?
rklepper Dignity-Esteem-Compassion 9,019 posts Gallery: 2 photos Likes: 14 Joined Dec 2003 Location: No longer living at the center of the known universe, moved just slightly to the right. Iowa, USA. More info | Dec 12, 2006 22:12 | #1 I have the anti twist plates for the 488 RC2 and lost one of the bolts and busings from the plate. Anyone know where you can get these parts where it makes sense, rather than just buying a new one? Doc Klepper in the USA
jrsforums Goldmember 1,249 posts Joined Feb 2005 Location: Cary (Raleigh), NC, USA More info | Dec 13, 2006 01:59 | #2 rklepper wrote in post #2392171 I have the anti twist plates for the 488 RC2 and lost one of the bolts and busings from the plate. Anyone know where you can get these parts where it makes sense, rather than just buying a new one? Doc...
But, frankly, the effort might be more than the $23. to replace the whole 3157NR John
rklepper THREAD STARTER Dignity-Esteem-Compassion 9,019 posts Gallery: 2 photos Likes: 14 Joined Dec 2003 Location: No longer living at the center of the known universe, moved just slightly to the right. Iowa, USA. More info | Dec 15, 2006 13:48 | #3 jrsforums wrote in post #2393060 Doc... I assume the 488RC2 came with the standard plate. Can't you use the bolt and 'C' washer from it? I'm too lazy to go upstairs to take mine appart to see if the bolts are the same length... ...but assume they are.If you are using the standard plate someplace else....some alternatives: - Buy a new std plate @ 11.95 vs. 22.95 (B&H) - If the std plate is in use, but semi-permenant...i.e. rarely removed, get a 1/4-20 bolt from a hardware store....I have used on base of my brackets. Might also find a 'C' washer, but.... If none of those work, here is info from The Bogen site: how can I obtain spare or replacement parts for any product carried by Bogen?
But, frankly, the effort might be more than the $23. to replace the whole 3157NR Thanks so much. I tried the standard one and the bolt is too short to fit. I will call bogen. Doc Klepper in the USA
MikeV Senior Member 271 posts Joined Sep 2006 More info | Dec 15, 2006 20:34 | #4 All that stuff is available as spare parts. o o o o
rklepper THREAD STARTER Dignity-Esteem-Compassion 9,019 posts Gallery: 2 photos Likes: 14 Joined Dec 2003 Location: No longer living at the center of the known universe, moved just slightly to the right. Iowa, USA. More info | Dec 15, 2006 22:31 | #5 Mike V wrote in post #2405757 All that stuff is available as spare parts. You mean through the bogen imaging linked above? Doc Klepper in the USA
| Latest registered member was a spammer, and banned as such! 2189 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
