Hi all, I have a question about AE lock in AV mode while using my external flash as a fill flash. I have read the book, and I am still a little confused. From my understanding, AE works as FE if your flash is on. So, if I want the camera to lock exposure for the background ( outdoors in AV mode ) then how would I do it. You see I don`t want my subject to be considered in the camera`s metering. SO my thought would be to pivot a little until my subject is out of the viewfinder, lock exposure for the background, pivot back and compose, take picture. I guess this workflow is not good simply because I have no AE lock function because my flash is on.
My reasoning for not wanting the subject in the viewfinder while the camera meters is simply because the bigger the difference between the subject and background, the bigger the camera will try and average it out, I want the camera to use the flash to compensate for the subjects exposure, and not change the exposure at all for the background. ( And I would still consider FEC down a bit - still have to experiment with that one )
Is this possible ? thanks a lot all
