30D with 18/55mm
Judging by this shot would you agree that the lens is of a decent optical quality ?
Dilligaf Member 87 posts Joined Dec 2006 Location: Cornwall England More info | Dec 13, 2006 18:20 | #1 30D with 18/55mm Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
Dec 14, 2006 11:58 | #2 Well I think it is Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
maybe not Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
Terrywoodenpic Senior Member 869 posts Joined Dec 2005 Location: Saddleworth England More info | Dec 16, 2006 15:13 | #4 What do you think? Terry_______________
I think the lens is good enough, I have read many posts since purchasing the camera, I was given the 18/55 mm f3.5 f5.6 by a photographer friend along with a centon 500mm (which I am told isn't a very good lens at all ) but I am sure I will enjoy what I get from it now I have read a few reports on it and not to expect too much from it. Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
pagefile Senior Member 586 posts Joined Aug 2006 Location: New Hampshire More info | Dec 16, 2006 22:32 | #6 I don't think that the images you posted would tell me if that lens is sharp or not. Post other images with this lens of like outside or people. It may help to see what it can do.
Ok I won't Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
Dec 20, 2006 10:24 | #8 The sharpness of a lens varies with the aperture. When wide open, most lenses are the least sharp that they will be throughout the openings. Generally speaking a lens is sharpest somewhere between two and three stops DOWN from maximum. The best way to determine at what aperture a lens is sharpest is to tack a newspaper on the wall, light it with two tungsten lights one on either side at a 45 dgeree angle, use a hand held meter and adjust your shutter speed until you get an aperture that is the same as your lens is at its widest opening. Mount the camera on a tripod, use a cable release (or timer) focus carefully and make one exposure at each aperture setting while making the needed exposure adjustments using the shutter speed. After finishing, load all of them in Photoshop and enlarge them up to 400% or so. You should be able to easily tell at what aperture the lens is sharpest.
Thanks Benji, much appreciated. My new 30D has been wrapped for xmas day Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
pagefile Senior Member 586 posts Joined Aug 2006 Location: New Hampshire More info | Dec 20, 2006 18:10 | #10 Dilligaf wrote in post #2425505 Thanks Benji, much appreciated. My new 30D has been wrapped for xmas day it is purgatory. But I shall do the newspaper test once the wrapping has been RIIIIIIIIIIIIIPPED off.You know that you don't have to wait for Christmas day. Christmas Eve you get to open one, its not much of a help. But if I had a 5D, 30D or a 20D under that tree, one day for me would help.
For sure pagefile....... as soon as that clock strikes midnight I will be ripping the paper off Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
| Latest registered member is ANebinger 997 guests, 178 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
