It's very sunny in Australia should i get a Polariser or Neutral Density?
And for how many stops 1, 2, 3?
I need a reply ASAP
lostdoggy King Duffus 4,787 posts Joined Aug 2004 Location: Queens, NY More info | Dec 13, 2006 19:57 | #2 All of the above!!!
scottbergerphoto Cream of the Crop 5,429 posts Likes: 1 Joined Jun 2003 Location: Brooklyn, NY, USA More info | They both serve different purposes. lostdoggy is correct. One World, One Voice Against Terror,
Michael Cream of the Crop 5,981 posts Likes: 3 Joined May 2006 Location: Perth, Western Australia More info | Dec 14, 2006 07:10 | #4 I use a C-Polariser some times if it is really bright, and im getting a lot of reflections. Not sure about a ND though. Are you asking what brands are good? Michael
MREGAN Member 246 posts Joined May 2006 Location: IRELAND More info | Sorry for jumping in here but I am looking for the same sort of thing. Although I am in Ireland not just as sunny. What are the purposes of the filters and on what occassions do I use them. I heard HOYA were a good manufacturor? I was told to go for a Circular Polarizer but there are different types and prices. Canon 300D
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Dec 14, 2006 11:21 | #6 A polarizer will help reduce reflections from non-metallic objects (glossy paint surfaces, glass, etc.) and will make blue skies (at an angle from the sun) more intense. Neutral density filters will reduce light across the board, if you need to use a wider aperture for DoF, or a slower shutter speed to blur motion (as in running water). Jon
MREGAN Member 246 posts Joined May 2006 Location: IRELAND More info | Cheers jon. Think I will buy both and see how I get on. I have a skylight 1A filter cant see any difference but then again I dont know what this type of filter does to look out for. Canon 300D
lostdoggy King Duffus 4,787 posts Joined Aug 2004 Location: Queens, NY More info | Dec 14, 2006 19:09 | #8 You do know there are Graduated Neutral Density Filter use when one half of the image/view is brighter then the other half.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Dec 14, 2006 19:31 | #9 Skylight 1A, like UV, will take out some of the UV and purple end of the spectrum, helping cut through haze (but not as well as a polarizer will). They're also used to protect the front element of a lens, but make sure you have a good multi-coated one. Mine are B+W or Hoya multicoated. Jon
| Latest registered member was a spammer, and banned as such! 2189 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
