If I set my ISO at 1600 and put a Polorazing filter, it means 2 F stops less. Thus I actually shoot with ISO 400. The noise level I get is it equivalent to 1600 or 400? Thanks for the info.
eaglesnest Member 189 posts Joined Jan 2006 Location: Ontario, Canada More info | Dec 13, 2006 22:54 | #1 If I set my ISO at 1600 and put a Polorazing filter, it means 2 F stops less. Thus I actually shoot with ISO 400. The noise level I get is it equivalent to 1600 or 400? Thanks for the info. www.eaglesnestphotography.com
Hermeto Cream of the Crop 6,674 posts Likes: 2 Joined Oct 2005 Location: Toronto, Canada More info | Dec 13, 2006 22:57 | #2 Permanent banNo, it is quite the opposite! What we see depends mainly on what we look for.
How can it be? By putting a Polarizing filter, the sensor will get less light, www.eaglesnestphotography.com
basroil Cream of the Crop 8,015 posts Likes: 2 Joined Mar 2006 Location: STL/Clayton, MO| NJ More info | Dec 13, 2006 23:36 | #4 wait, what???? I don't hate macs or OSX, I hate people and statements that portray them as better than anything else. Macs are A solution, not THE solution. Get a good desktop i7 with Windows 7 and come tell me that sucks for photo or video editing.
gacon1 Senior Member 639 posts Likes: 4 Joined Mar 2006 More info | Dec 13, 2006 23:42 | #5 basroil wrote in post #2397639 wait, what???? iso is iso, it isn't affected by anything but the level you put your camera in (50, 100, 200, 400, 800, 1600, 3200).. I do agree
Hermeto Cream of the Crop 6,674 posts Likes: 2 Joined Oct 2005 Location: Toronto, Canada More info | Dec 13, 2006 23:53 | #6 Permanent baneaglesnest wrote in post #2397497 How can it be? By putting a Polarizing filter, the sensor will get less light, means your ISO also drops by 2 f stops. Am I right? If CPL reduces amount of light on the sensor by 2 stops, that 2 stops of light have to be compensated somehow. What we see depends mainly on what we look for.
tsaraleksi Goldmember 1,653 posts Likes: 1 Joined Sep 2006 Location: Greencastle/Lafayette Indiana, USA More info | Dec 14, 2006 00:17 | #7 Put in simple terms. A polarizer is like being in light that is two stops darker. --Alex Editorial Portfolio
Hermeto Cream of the Crop 6,674 posts Likes: 2 Joined Oct 2005 Location: Toronto, Canada More info | Dec 14, 2006 00:22 | #8 Permanent banExactly! What we see depends mainly on what we look for.
Thanks for all your response. But you missed my question. I simply ask for the noise level effect. www.eaglesnestphotography.com
Hermeto Cream of the Crop 6,674 posts Likes: 2 Joined Oct 2005 Location: Toronto, Canada More info | Permanent banThat is quite possible. What we see depends mainly on what we look for.
gcogger Goldmember 2,554 posts Likes: 1 Joined Mar 2003 Location: Southampton, UK More info | Dec 14, 2006 07:26 | #11 If you set the camera to ISO 1600, the noise level will be the same whatever you put in front of the lens. So no, the noise wil absolutely NOT be the same as ISO 400! If you compensate for the loss of light by changing aperture or shutter speed then that's all there is to it. Graeme
canoflan Goldmember 1,059 posts Joined Jul 2006 Location: Texas, US More info | Permanent bannoise is mainly (but not always) determined by your ISO setting, period.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Dec 14, 2006 09:05 | #13 eaglesnest wrote in post #2397460 If I set my ISO at 1600 and put a Polorazing filter, it means 2 F stops less. Thus I actually shoot with ISO 400. The noise level I get is it equivalent to 1600 or 400? Thanks for the info. You're stil shooting at ISO 1600, just with less available light. ISO isn't related to the amount of light coming into the camera through the lens; it's a measure of how much the signal from the sensor is amplified. So you'll still get ISO 1600-level noise. Jon
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Dec 14, 2006 09:32 | #14 ISO on digital cameras seems to not be understood well. Essentially (perhaps oversimplified) the ISO value goes up when the amplification of the signal hitting the sensor goes up. But it isn't only the real signal, it is also the inherent noise in the circuitry that gets amplified. I have prepped a chart showing this effect, where high ISO lowers the signal:noise ratio so that we see the noise. I just noticed a wrong label...the column labeled "GainB" should be labeled "NoiseB" You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
superdiver Cream of the Crop 9,862 posts Likes: 5 Joined Jan 2006 Location: Ketchikan Alaska More info | Dec 14, 2006 10:59 | #15 gcogger wrote in post #2398664 If you set the camera to ISO 1600, the noise level will be the same whatever you put in front of the lens. So no, the noise wil absolutely NOT be the same as ISO 400! If you compensate for the loss of light by changing aperture or shutter speed then that's all there is to it. If, however, you keep aperture/shutter speed the same then the image will be under-exposed by 2 stops. In that case, the noise level is still the same (i.e. ISO 1600). BUT - when you process the image to compensate for it being too dark, you will amplify the noise so that it looks more like ISO 6400! This has been my experience...not sure if its "scientific" or not, but when you UNDERexpose due to filters and then adjust in PPing the noise levels INcrease dramatically. I can understand how tthere can not be a TRUE ISO comparison, but the effect is ALOT more noise... 40D, davidalbertsonphotography.com
| Latest registered member was a spammer, and banned as such! 2487 guests, 104 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
