Thread started 14 Dec 2006 (Thursday) 04:47
Error during Backup
jdmaertz
1 post
Dec 14, 2006 04:47 |  #1
I am having problems backing up photos to a CD-R. After the backup session is completed, I get an error message that reads:
An error occurred while verifying the files were successfully written to the CD. Incorrect Function
Any thoughts?
TeeJay
Joined Jun 2005
Dec 14, 2006 05:24 |  #2
It would certainly appear that there is an error in the data recorded.
Are you using a make of CD-R that you have used before? ... and, can you save any other files/data to a CD from this batch?
I would suggest you try a different make/brand of CD-R, preferably a well-known brand.
TJ
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
Jon
Joined Jun 2004
Dec 14, 2006 11:55 |  #3
How are you making the backup? and do you have, say, MS Raw viewer Power Toy installed? I've found that some of the supplementary data files (thumbs.db, zbthumb.info, etc.) may change or get updated while you're making the backup and thus not match what got burned to the CD when the verification pass is finished.
Jon
Cocker Spaniels
TeeJay
Joined Jun 2005
Dec 15, 2006 03:58 |  #4
Jon makes a good point. Why not try switching off the verification, then just manualy checking the CD when it's finished?
20D-Newbe
Dec 15, 2006 04:06 as a reply to  @ TeeJay's post |  #5
Just a small point - I though that the verification did not do a bit for bit comparison – but just a check from the media (i.e. if the data can be read from the CD).
Andy
Canon
20D w/Grip BG-E2 Twin Canon 511A's & Twin SterlingTek 511's
EF 16-35mm f2.8 L w/Hood & Tokina UV filter
EF 28-135mm f3.5-5.6 IS USM w/Hood & Jessops UV filter
Sigma 50-500mm f4-6.3 APO DG HSM w/Hood & Hoya UV filter & 1.4x t-con
EF 70-200mm 2.8 L IS USM w/Hood & B&W UV filter
TC-80N3 Timer Remote Controller
Speedlite 580EX
1x 1GB (80x) Lexar, 1x 1GB & 2x 512Mb Jessops CF :o
Manfrotto 458B w/405 Geared head
Ixus 400 - as general backup or when I have the wrong lens on the D20 (Doh!!!)
TeeJay
Joined Jun 2005
Dec 15, 2006 04:21 |  #6
Yes, but if Jon is correct, it is simply checking & comparing file dates/sizes, in which case that might be throwing it.(?)
Jon
Joined Jun 2004
Dec 16, 2006 09:38 |  #7
20D-Newbe wrote in post #2402725 (external link)
Depends on what application you're using. Which is why I asked. Some check readability, som compare files, some compare directory entries.
Jon
Cocker Spaniels
Eagle
Gallery: 62 photos
Dec 16, 2006 21:07 as a reply to  @ Jon's post |  #8
As well as what software you are using it would probably help if you listed step by step how you are doing it. An auto function or walking through a wizard or some type of manual backup.
7D MKII ■ 10-22 ■ 15-85 ■ 28-135 ■ Σ 50-150 ■ 70-200 f4L ■ 100-400L ■ 580EX II
Gear-PCSmugMug (external link) ShutterStock (external link) Alamy (external link) Eagle's Nest Photography (external link)
1,512 views & 0 likes for this thread, 5 members have posted to it.
Error during Backup
2189 guests, 138 members online
