Thread started 14 Dec 2006 (Thursday) 23:09
Red Raider Basketball
Crashoran
Joined Nov 2005
Dec 14, 2006 23:09 |  #1
Vs. Oral Roberts - 12/14/06
Palladium
Dec 14, 2006 23:34 |  #2
Great series...
Generally what lens combo do baseline shooters use for college B Ball?
Crashoran
Joined Nov 2005
Dec 14, 2006 23:48 |  #3
They generally use a 70-200 and 300 on seperate bodies. Right now I am using the 85 and 300 on one body.
Palladium
Dec 14, 2006 23:58 |  #4
Crashoran wrote in post #2402260 (external link)
Thanks for the info - How about for under the basket wide stuff?
24mm f1.4 ?
35mm f1.4 ?
16-35mm 2.8 ?
The reason I ask is I'm thinkg about adding something to my kit ;)
grego
Dec 15, 2006 00:11 |  #5
Palladium wrote in post #2402305 (external link)
24mm f1.4 ?
35mm f1.4 ?
16-35mm 2.8 ?
Those will work fine, but you will want something longer on another body. I lot depends on what gym you are in, but the 16-35 would be most versatile.
You'd want something in the 70-200 range, 85 1.8, 100 2, etc.
Go UCLA (external link)!! |Gear|http://gregburmann.com (external link)SportsShooter (external link)|Flickr (external link)|
Palladium
Dec 15, 2006 00:28 |  #6
grego wrote in post #2402347 (external link)
Thanks - I think I have the long end covered it's the short end that I think I need to pick up.
grego
Dec 15, 2006 01:44 |  #7
Palladium wrote in post #2402380 (external link)
Since you got the long end covered, Something aroudn 35mm would do fairly well, for the shorter end.
Crashoran
Joined Nov 2005
Dec 15, 2006 12:49 |  #8
Any tips on how to get rid of the yellow hue reflecting from the floor?
grego
Dec 15, 2006 12:53 |  #9
Crashoran wrote in post #2404079 (external link)
You can use "color balance" or "selective colors" . I'd prefer the latter because its more detailed and you can specify much more. It will help clean up the color balance.
creechjs
Dec 15, 2006 16:32 |  #10
grego wrote in post #2404104 (external link)
I generally use color balance as he said, but if your just talking about the yellow hue on the white jerseys you can desaturate the yellow some using a hue/saturation adjustment map.
Jeff Creech Photography
My website - http://jeffcreech.com (external link)
Import Tuner - Modified Magazine - Modified Luxury and Exotics - Modified Mustangs - Turbo Magazine - Honda Tuning
Palladium
Dec 15, 2006 17:06 |  #11
NIK has a great filter in the NIK Color Effect Pro 2.0 called
White Neutralizer
I did a few workups on your images and I think it really enhances them. Let me know and I e-mail you the workups.
you can take a look at one of my white neutrizer workups in this thread
https://photography-on-the.net/forum/showthre​ad.php?t=251139
Crashoran
Joined Nov 2005
Dec 15, 2006 18:18 |  #12
One more:
Palladium, post some samples of your corrections
DarrenL
Dec 15, 2006 18:27 |  #13
Wow. Top class images. Amazing sharp and I can see very little visible noise in the images. Have you still got the EXIF data. I'd love images that sharp.
Darren
www.dlactionimages.co.​uk (external link)
Sportsshooter Member (external link)
jevidon
Dec 15, 2006 18:28 |  #14
looking good on sharpness, color and noise..... my only negative comment is that you're cropping too close - you keep cutting off the ball or heads... otherwise nice work.
Justin Evidon
Minneapolis, MN
http://www.justinevido​n.com (external link)
grego
Dec 15, 2006 18:30 |  #15
DarrenL wrote in post #2405349 (external link)
Darren
Most division 1 gyms will give you around ISO 1000-1600. You should be able to get sufficient shutter speeds, and if exposed right, you won't see much noise.
1,664 views & 0 likes for this thread, 6 members have posted to it.
1579 guests, 117 members online
