Thread started 15 Dec 2006 (Friday) 12:01
5D good for sports
mergino
Joined Jan 2005
Dec 15, 2006 12:01 |  #1
Is 3fps & less telephoto reach a problem?
canoflan
Dec 15, 2006 12:12 |  #2
For sports, getting the framing is more important than the speed of the camera, IMHO. 3 fps should be fine, and you should try and observe to see when activity you want to catch may flare up. I would get the zoom ability before the camera. If you can get both, get the lesser camera, and better zoom.
Rumjungle
Dec 15, 2006 12:12 |  #3
What kind of sports are you planning on covering?
Gear
scottbergerphoto
Joined Jun 2003
Dec 15, 2006 12:22 as a reply to  @ Rumjungle's post |  #4
For sports, nothing beats the autofocus performance of the 1DMII/1DMIIN. It's not the fps as much as it is the AF performance. The 5D has 9 AF points, the 1DMII/N have 45 AF points.
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
canoflan
Dec 15, 2006 12:54 |  #5
mergino wrote in post #2403930 (external link)
What's your budget? 1DMIIN is the standard. If you must go below that, then 30D is the next in line for speed.;)
sjafari
Dec 15, 2006 13:07 |  #6
i think it depends on the sports youre shooting, but i would agree that the 1DmIIN is the way to go, if not, go with the 30D. The crop will help you get a little closer with the same aperture, and the AF speed and continuous shooting abilities of the IIn are unparalled. the 5d has great quality, but the 3fps will be your limiting factor. If you are going to shoot sports like curling or something, it should plenty fast.
-Shehab-
http://www.fotojafari.​net (external link)
5Dii, 16-35/2.8ii, 24-70/2.8, 135/2
lummy
Dec 15, 2006 13:10 as a reply to  @ sjafari's post |  #7
Just out of curiosity, is the the 1d mII (no N) being excluded solely because you can't buy it new?
dontblink
Dec 15, 2006 19:39 |  #8
lummy wrote in post #2404182 (external link)
Pretty much. Very little difference between the 1DmII and 1DmII2, even less difference than between the 20D and the 30D.
Canon 20D + grip
EF: 28mm f/1.8 & 50mm f/1.4
EF: 24-105mm f/4
L IS & 70-200mm f/2.8 L IS
EF-S:
10-22mm f/3.5-4.5 & 17-55mm f/2.8 IS
thekid24
pro-zack-lee
Dec 15, 2006 20:23 |  #9
i kinda asked the same question and i was told yeah 3fps are a little limited.not that it couldnt be done,but you would have to be guessing alot on when to fire of teh 3 frames.Mk2N is the one to go with followed by the 30D.i think some people forget how fast things happen during any kind of sports activity,so every fps can only be better.And as anyone knows here gLass is a must.So if you had to choose between gLass or body,go with gLass.You can always upgrade a better body,who knows by the time the $$ is saved,it could be alot cheaper with rebates and newer models being out.
But to answer the question....if 3fps and less telephoto a problem,yeah unless u want to take a shot of the entire field/team/court.
DavidEB
Dec 15, 2006 21:19 |  #10
I agree with Scott, sort of. For me the single biggest gain going from 20D to 1D was AF performance. The 1D is quick to focus and accurate. But I mostly only use 1 AF point for sports.
Frames per second is a crutch - develop good timing. Most of my favorite shots are one at a time.
David
my stuff - [URL="http://www.pbase​.com/davideb"]my gallery - [URL="http://photograp​hy-on-the.net/forum/showpost​.php?p=3928125&postcou​nt=1"]go Rats!
grego
Dec 16, 2006 04:52 |  #11
The 1DMKII/MKIIn, are the ultimate sports cameras. However, for certain sports that 5D is more than adequate.
Go UCLA (external link)!! |Gear|http://gregburmann.com (external link)SportsShooter (external link)|Flickr (external link)|
otlip
Joined Jul 2004
Dec 16, 2006 09:18 |  #12
Good Morning and top to the season to all,
Presently I have the 300D and the 100-400 IS, how well will this lense work with the 1DmIIN. I will be using it for sports mostly. Does anyone have this combo and how do they like it.
Thanks for your time,
Richard
scottbergerphoto
Joined Jun 2003
Dec 18, 2006 08:33 as a reply to  @ otlip's post |  #13
The 100-400 IS L is a great lens in good lighting. It suffers badly in poor lighting and low contrast lighting.
Best Regards,
Scott
steveathome
Gallery: 19 photos
Dec 18, 2006 13:03 |  #14
Manual focus, of which most seem to forget about, is the best, after some practice
Anders ­ Östberg
Joined Nov 2003
Dec 18, 2006 17:00 |  #15
steveathome wrote in post #2416170 (external link)
I can't agree with that, at least I am not able to focus manually and consistantly do it faster or as precise as my 1D(s) II cameras. Especially not for the combination of shallow DoF and action sports/motorsports.
Anders Östberg - Mostly Canon gear - My photos (external link)
7,348 views & 0 likes for this thread, 37 members have posted to it.
5D good for sports
2728 guests, 159 members online
