Thread started 16 Dec 2006 (Saturday) 00:41
Good reason to shoot RAW...
braduardo
Dec 16, 2006 00:41 |  #1
It's just amazing how far you can push your images when you do...
My flash didn't fire, so the JPEG image looked like this:
Since I shot it in RAW, I was able to push the exposure up +4.00 stops, and gain about 2 more stops by adjusting the brightness. The color noise was terrible, so I desaturated it and ended up with this:
While it looks like it's too grainy at this size, it turned out awesome printed 11x14. I actually like the grainy effect, and out of the 5-6 shots I took, this is my favorite, even if you count the ones where the flash actually fired.
:rolleyes: ----Brad---- :rolleyes:
www.nybergstudio.com (external link)
40D: EF 17-40 f4 L ---- EF 70-200mm f4 L ---- EF 50mm f1.4 ---- EF 85mm f1.8
calicokat
Dec 16, 2006 03:51 |  #2
Wow, its amazing you got that from blackness
"You are going to fall off a cliff trying to get a better shot someday"- My hopeful and loving wife :eek: :twisted:
My Website (external link)
Calicokat 1990-2007 RIP My Loving Kitty
joegolf68
Joined Nov 2005
Dec 16, 2006 03:56 |  #3
lol, yes, a real advertisement for RAW. ;)
:D Peace be upon you :D
prep
Dec 16, 2006 08:38 |  #4
In fact, if you have a good pile of bias frame, and average them, you can then subtract that from the un-demossiaced raw and reduce the fixed pattern noise! Even better is to also correct for dark current, and then multiply it all by a flat.
~pr
braduardo
Dec 16, 2006 09:27 |  #5
prep wrote in post #2407307 (external link)
Who's-a-jigga-what? :confused:
Dilligaf
Dec 16, 2006 09:34 |  #6
Pardon ;)
Canon 30D with 18/55mm,Kerso 50mm 1.8 Canon 135mm f/2.8 s/f.
Hellashot
Joined Sep 2004
Dec 16, 2006 09:39 |  #7
But it's still not a useable image for even printing 4x6 with those vertical lines. That shot was just too dark to begin with.
This is a better example of a recovered RAW file.
Flash went off by at maybe 1/8 power, iso200, 1/50, f6.3, pushed 3.15 stops in PSE3, no NR, and the one is as-shot settings, the other is a 100% crop of my subject's eyes, 6MP Drebel with Sigma 24-135.
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
prep
Dec 16, 2006 09:55 |  #8
A bias frame is a `zero exposure' dark frame. Set your speed right up, and shoot with the body capped and the viewfinder covered. By doing several of them, you can average them and have an image of the fixed patern noise in YOUR camera. Most of the vertical and horizontal streaking can be removed this way.
When your exposure gets longer, dark current adds to the noise, and this can also be corrected if you have dark frames of the correct time taken at the same temp. Again, for your specific body.
A flat is a blank iluminated field with no detail or variation. Thus, and change in value is a result of lens vigneting etc, or uneven sensitivity of each pixel. So by making up a master flat from many flat averaged out, you can use that to `flattern' the gain across the entire chip.
You don't want a lens on, because that has been shown to generate noise of its own from the focus and f stop controll, and also from IS. It is an idea to check for this though. Some lenses have new main PCBs that cut noise injected into the body via the power lines.
There are a couple of astronomy SW packages that will do most of this, but documtation is less than wonderfull.
Also Roger Clark's web site a a treasure trove that EVERYONE should go right through.
~pr
braduardo
Dec 16, 2006 10:25 |  #9
Hellashot wrote in post #2407510 (external link)
Unuseable is kinda in the eyes of the beholder... I have it printed 11x14, and in a black frame, and I love it. It is a VERY extreme example, and for most shots, it wouldn't do, but for this one I love the effect that came naturally. I've even taken this approach intentionally for a few shots where I wanted a lot of grain.
Elbee19
Joined May 2004
Dec 16, 2006 11:40 |  #10
All of the technical jargon aside...RAW=safety net! This thread is proving once again that by shooting RAW, when we make the mistake of shooting before switching out of previous settings and having it all wrong, we still just may capture something useable! ;)
Cheers,
LeBaron
Canon 1DMKiii/5D/40D/30D | Canon EF 70-200 mm f/2.8L IS USM | Canon 17-40 F4L USM | Canon 18-55mm F3.5-5.6 | Canon 50mm 1.8
whiteflyer
Gallery: 316 photos
Dec 16, 2006 11:59 as a reply to  @ Elbee19's post |  #11
RAW is the savour of cock-ups.
My photography would be VERY expensive if I shot on film :D
Fureinku
Dec 16, 2006 12:05 |  #12
^ amazing, im going to have to get more memory cards :\
Gear List | Wish List |
Dorman
Joined Feb 2006
Dec 16, 2006 22:58 |  #13
Wow, pretty neat results from pitch black.
I too shoot exclusively RAW for the safety net and for the control over my final product.
Mediasoldier
Dec 16, 2006 23:31 |  #14
If only I could take the time to figure out how to successfully use raw, this would have helped A LOT in the volleyball game I shot the other night. I just shoot JPEG, even though I know I should be shooting raw (I have 3gb, and rarely come close to filling). I honestly don't have a good reason for not trying :P
Photography of Trevor Henry (external link)
Canon Digital Rebel XT (350D) w/ BG-E3 Grip
Canon EF-S 18-55mm | Canon 50mm f/1.8 MkII |
Sigma 105mm EX DG Macro | Sigma 70-300mm DG MACRO | Sigma 10-20mm EX DG
BradT0517
I almost caught fire
Dec 16, 2006 23:38 |  #15
Personally I love the way brads shot looks because it has the feel that it is taken through canvas or something to give it an old rough texture
2,462 views & 0 likes for this thread, 15 members have posted to it.
1687 guests, 105 members online
