I am a beginner photographer, but I'm learning: I have a Sigma EF-500 DG Super Flash, that takes pictures that are very underexposed, about 80% of the time. The pop-up flash does a better job. I've dialed in 1.5+ exposure on my Digital Rebel. I've setup a tripod and taken 10 pics of the same object, and still have the problem. Even with the exposure upped I still have to post process them up by 1 to 2 + exposure. Some are so grainy they are discarded. I've tried setting identical settings, iso, shutter, f-stop, and still get different results. The only thing I can see sometimes is that the two pics will have the same focal length (ie 55mm)in EXIF data and they don't look like they should.
Thanks for any suggestions:
Gary
EXIF data:
Underexposed pic
Model = Canon EOS DIGITAL REBEL
Orientation = top/left
X Resolution = 350
Y Resolution = 350
Resolution Unit = inch
Software = Digital Photo Professional
Date Time = 2006-12-13 21:47:30
YCbCr Positioning = centered
Exif IFD Pointer = Offset: 148
[Camera]
Exposure Time = 1/60"
F Number = F5.6
ISO Speed Ratings = 400
Exif Version = Version 2.2
Date Time Original = 2006-12-13 21:47:30
Date Time Digitized = 2006-12-13 21:47:30
Components Configuration = YCbcr
Shutter Speed Value = 5.91 TV
Aperture Value = 4.97 AV
Exposure Bias Value = +1.33EV
Max Aperture Value = F5.6
Flash = On
Focal Length = 55mm
Flashpix Version = Version 1.0
Color Space = sRGB
Exif Image Width = 2048
Exif Image Height = 3072
Focal Plane X Resolution = 3443.946
Focal Plane Y Resolution = 3442.017
Focal Plane Resolution Unit = inch
Sensing Method = One-chip color area sensor
File Source = DSC
Custom Rendered = Normal process
Exposure Mode = Auto exposure
White Balance = Auto white balance
Scene Capture Type = Normal
Exposure OK
X Resolution = 350
Y Resolution = 350
Date Time = 2006-12-13 21:47:52
[Camera]
F Number = F5.6
Date Time Original = 2006-12-13 21:47:52
Date Time Digitized = 2006-12-13 21:47:52
Flash = On
Focal Length = 55mm
Color Space = sRGB
File Source = DSC
[Thumbnail Info]
Compression = JPEG Compressed (Thumbnail)
X Resolution = 72
Y Resolution = 72
JPEG Interchange Format = Offset: 772
JPEG Interchange Format Length = Length: 8261
