Thread started 16 Dec 2006 (Saturday) 12:26
S2-IS Movie Problem
JIMCHI
Dec 16, 2006 12:26 |  #1
I have have absolutely no problems taking movies using a 1GB High-Speed 60x SD card (made by PQI) and using the highest resolution. I usually can get about 30 minutes of video with no slowdowns and great results. I recently purchased two 2GB cards, identical to the 1GB cards (same manufacturer, same 60x speed). Using either one of those 2GB cards, I can only get 20 seconds of video at the highest resolution before I get a "busy" warning at the bottom of the screen and the movie mode stops. However, if I change the resolution to 320x240 at 30fps I can again record about 30 mins of video. I called Canon and they say the camera isn't the problem. How could just increasing the size of the SD card cause this problem?
HTTP response: 403 | MIME changed to 'text/html'
2Shiny
Dec 16, 2006 13:07 |  #2
Did you format the cards with the camera?
Paul
D20, SX40
JIMCHI
Dec 16, 2006 13:21 as a reply to  @ 2Shiny's post |  #3
Yes.
Jon
Joined Jun 2004
Dec 16, 2006 15:32 |  #4
Did you get them via eBay? Unfortunately, it's overrun with counterfeit cards it seems.
The othe possibility you may be seeing is that the design of the PQI cards pre-dates the "official" extension of SD spec to 2 GB, and the tweaks they used to get there just can't cope with that speed.
I will say that I find my A620 maxes out at 9 min/GB storage at best resolution (640x480x30 fps), so I'm a little surprised that the S2 can do a half hour at that resolution.
Jon
Cocker Spaniels
JIMCHI
Dec 16, 2006 18:04 as a reply to  @ Jon's post |  #5
I purchased the all the PQI cards at Fry's. The 2GB cards are only 2 months old. I've never had a problem getting from 25-35 minutes of video on a 1GB card at the 640x480 30fps resolution. I think the problem is the buffer is getting full, but why is it getting full after only 20 seconds with the 2GB card while it never got full with the 1GB card?
Jon
Joined Jun 2004
Dec 16, 2006 21:37 |  #6
That brings us back to the 2 GB card size; if the PQI cards are an older design, before there was a real standard for SD cards larger than 1 GB, they would have had to play tricks with the system to get that much addressable memory, and that would present problems. I know that my 2 GB SanDisk (blue and Ultra II) both can handle a full 1 GB of video at 640x480x30 fps. Can you borrow a SanDisk card and see what it does?
Jon
Cocker Spaniels
mishnogram
Dec 17, 2006 10:49 |  #7
I don't think its possible to get 20 to 30 minutes of video on a 1Gig card on the S2 since the Canon website has the S2 at 1.9MB/sec at the highest setting. A 512 MB card is rated for 237 seconds or about 4 minutes and about double that for a 1 gig card. Everyone I've talked to and every review I've read seems to agree with this. I would guess that maybe you have it set to a lower quality video setting? MY SD Card running at X45 speed doesn't show any slowdowns during filming but longest I've taken was 4 or 5 minutes.
Min
Canon Rebel xt with kit len, Sigma 55-200mm F4-5.6 DC, Canon S2IS, & not enough time to use them all.
http://picasaweb.googl​e.com/mishnogram (external link)
ssd
Dec 18, 2006 11:07 |  #8
mishnogram wrote in post #2411428 (external link)
I agree absolutely........ with best resolution and 30fps one can get max of 8 min video on 1 GB. The camera becomes 'busy' after 8 min (approx). I took exactly 7 min of video at a time on a 2GB card (50x) without hint of any problem.
EOS 500 D
ssd
Dec 18, 2006 11:12 |  #9
JIMCHI wrote in post #2409054 (external link)
You must be making a mistake about either resolution or fps setting. With the setting you gave, one can have only 8min (max) of video on 1GB.
EOS 500 D
Jon
Joined Jun 2004
Dec 18, 2006 12:15 |  #10
Jon wrote in post #2408504 (external link)
ssd wrote in post #2415763 (external link)
Could you check your settings again? I really don't think you're getting 20-30 min. on a 1 GB card at 640x480x30 fps.
Jon
Cocker Spaniels
1,198 views & 0 likes for this thread, 5 members have posted to it.
S2-IS Movie Problem
2296 guests, 134 members online
