Thanks alot guys.
Jackie - Something I learned from this set most of all, is how much easier it makes everything if you do your prep work ahead of time. When I shoot my friends, it's usually semi spontaneous and a case of "ok well, let's go here" or "ok, let me just try setting up the strobes in a manner I'll come up with as I go". This time because I was so worried about screwing it up I actually went to my locations ahead of time and looked at angles, the way the light fell, everything. I actually even focused on about the spot I would have them standing so I could see how the background would blur before I took the photos. A bit overdoing it? Maybe so, but nonetheless when it was time to do the shoot it was so easy as I didn't really have to focus on anything other than putting them in the right place and taking the photos. Everything else was already settled which was so helpful because it took all the scrambling and pressure out of shooting. I knew everything would work out, so there was no need to worry
