Thread started 17 Dec 2006 (Sunday) 09:26
Silly question relating to the 350d battery grip
Cerbera
Dec 17, 2006 09:26 |  #1
I've purchased (well my mom has) a battery grip for my 350d (both are for xmas), and i was thinking.. will i need to buy two additional batteries or just one? As i wasnt too sure if the battery grip fits into where the standard battery goes, which would mean i only need one additional battery rather than 2.
Thanks for your time.
Canon EOS 450D DSLR, Battery Grip BG-E5,canon EFS 18-55mm IS Kit lense, Canon 50mm 1.8, Tamron 70-300mm. Cokin P Series Holder: CP/UV/4 star/ND Kit
Speedlite 430Ex II,Lowepro 200AW bag
g_robins
Dec 17, 2006 10:30 |  #2
you have to remove the battery from the 350d, then remove the little door that holds the battery in place. then the battery grip fits inside the camera and secures from underneath. then you can use one or two batterys in the grip. beaware that if you use one battery it has to go in the slot that says one.
2x Canon 1D MkIII, Canon 70-200mm f/2.8L IS, Sigma 24-70mm f2.8, Canon 17-40mm f4,Sigma 10-20mm, Canon EF 24-105mm f4 L IS USM, 2x Canon 580 EX Flash,Yongnuo 565 Flash, Lowepro Magnum AW, Lowepro belt system.
:(:lol::(
Have a look at www.grahamrobins.net (external link)
Vini
Dec 17, 2006 11:11 |  #3
Like g_robins said, it will take one. It would make more sense to use 2 batterys, last twice as long. I have the original canon battery and 4 others. The others are in my opinion better, for a start there alot cheaper and mine are 1000mAh rather than the canons 720mAh. They can be charged off your charger. For some reason i never mix them in the battery grip. Not sure how much the canon battery is but i paid £10 each for the copies. ;) It will take 4xAA's as well.
MY PHOTOS
http://www.flickr.com/​photos/viniryan/ (external link)
MY GEAR LIST
[350D] [KIT LENS] [17-40L:D ] [SIG 105 MACRO] [SIG 70-300] [KENKO EX TUBES] [430EX] [FLASH BRACKET] [BG-E3 BAT GRIP] [MANFROTTO MONO+TRIPOD] [AND LOADS OF BITS]
Hermeto
Dec 17, 2006 11:33 |  #4
Vini wrote in post #2411503 (external link)
Six AA’s actually.
They will not hold charge as long as two NB-2LHs, use them only in emergency..
Vini
Dec 17, 2006 12:27 |  #5
Hermeto wrote in post #2411554 (external link)
Six AA’s actually.
:rolleyes: sorry 6 AA's.
MY PHOTOS
MY GEAR LIST
uniqueimaging
Dec 17, 2006 13:05 |  #6
it actually does not matter which slot you use one battery in. you can only use one certain slot for the AC adapter kit.
Rebel XT w/ grip
EF-S 18-55mm f/3.5-5.6 USM
EF 100-300mm f/4.5-5.6 USM
Tokina 10-17mm f/3.5-4.5 DX fisheye zoom
Speedlite 430EX
1,285 views & 0 likes for this thread, 5 members have posted to it.
1687 guests, 105 members online
