Hi All
Last weekend I purchased a A710is
. After installing the software and connecting the camera, Windows XP (Explorer) recognises the camera as a "Canon PowerShot A710 IS", but no drive letter is associated with the camera. When I start up ZoomBrowser EX (V5.7) and then try to connect to the camera via "Aquire & Camera Settings" > "Aquire Images from Memory card", nothing happens
, I also cannot connect to the camera via "Connect to the Camera" I have a SD card reader, when I use this with ZoomBrowser EX I can select "Aquire & Camera Settings" > "Aquire Images from Memory Card" and then Zoombrowser opens up the image window.
I have a Nikon D70, when I use this camera with ZoomBrowser I can download my photos via "Aquire Images from Memory Card". The Nikon D70 appears as a drive letter within Windows explorer (When connecting the D70 directly to the USB port).
It appears that Windows XP is not assigning a drive letter to the A710IS, could someone confirm if a drive letter should be assigned ?
Has anyone else got any suggestions to fix this problem.
(BTW, I have already removed RealPlay 10, searching Google I have found a few people with a similar problem).
Cheers
Nick
