Thread started 19 Dec 2006 (Tuesday) 19:13
400L 5.6 and teleconverter
iterrier
Joined Nov 2005
Dec 19, 2006 19:13 |  #1
I apologize if this has been covered, but I did a search and did not find a satisfactory answer to the following question: is there a teleconverter made that can be used with the L400 5.6 so that autofocus is not lost?
I would like to get the 400 5.6 to use for bird photography, and the addition of a teleconverter would be great.
Joan
30D
EFS 17-55, 400 5.6 L
100-400 L IS,70-200 2.8 L IS
Tamron 1.4 TC
seanm
Gallery: 25 photos
Dec 19, 2006 19:15 |  #2
I believe the Tamron 1.4 will do the job.
Sean
C&C welcome.
cjm
Gallery: 11 photos
Dec 19, 2006 20:23 |  #3
The Canon 1.4x TC I believe will also.
Christopher J. Martin
imagesbychristopher.co​m (external link)
seanm
Gallery: 25 photos
Dec 19, 2006 20:24 |  #4
Really? I could have sworn you loose AF with the canon TC...
Sean
C&C welcome.
iterrier
Joined Nov 2005
Dec 19, 2006 20:31 as a reply to  @ seanm's post |  #5
I read that the AF mechanism will be lost on the digital rebels, 20D and 30D with the canon 1.4 converter, but will be retained on full frame cameras. I have a rebel XT, and will most likely stay with the smaller sensors.
Seanm, which tamron 1.4 teleconverter are you referring to? I see more than one mentioned on the B&H website.
Joan
30D
Tamron 1.4 TC
Jman13
Dec 19, 2006 20:31 |  #6
You'll lose AF with the 30D. You'll retain AF with the 1-series bodies. However, if you tape certain pins (not sure which), the aperture won't be reported to the camera, and so AF will remain (though it won't be very good).
Jordan Steele - http://www.jsteelephot​os.com (external link) | https://www.admiringli​ght.com (external link)
Canon EOS R5 | R6 | TTArtisan 11mm Fisheye | Sigma 14-24mm f/2.8 | RF 24-105mm f/4L IS | Tamron 35mm f/1.4 | RF 35mm f/1.8 | RF 50mm f/1.8 | RF 85mm f/2 | RF 70-200mm f/2.8L IS | Sigma 135mm f/1.8
Roy ­ C
Dec 19, 2006 20:54 |  #7
cjm wrote in post #2422325 (external link)
Only if you tape the last three pins to fool the camera into thinking that a tc is not present. I use a Canon 1.4 with the 400mm f5.6 in this way.
TOP BIRD SHOTS (external link)
MY PHOTOSTREAM (external link)
500px gallery (external link)
Permagrin
Dec 19, 2006 20:56 as a reply to  @ Roy C's post |  #8
You could buy a non reporting tc (kenko 1.5x, not the teleplus pro series) and not lose AF but it can be slow focusing...don't know that I'd do it.
iterrier
Joined Nov 2005
Dec 20, 2006 05:37 |  #9
Roy C wrote in post #2422453 (external link)
If you tape the pins on the canon, is the af as fast as without the pins? Does the lens seem to search?
Joan
30D
Tamron 1.4 TC
kross
Dec 20, 2006 06:10 |  #10
iterrier wrote in post #2423956 (external link)
it hunts a lot....
cheers....
flickr (external link) me....
Broncobear
Dec 20, 2006 06:14 |  #11
kross wrote in post #2424016 (external link)
it hunts a lot....
cheers....
I'm imagine it be a pain, especially in bird watching when it hunts and the birs is gone by the time it's finally able to take a shot.
"The real voyage of discovery consists not in seeking new landscapes, but in having new eyes." " (external link)Marcel Proust (external link)
Gear& Frank's Flickr (external link)
kross
Dec 20, 2006 06:17 |  #12
Broncobear wrote in post #2424028 (external link)
yup, my mfing is faster than using the af with 1.4x tc....:rolleyes:
cheers....
Cadwell
Joined Jan 2004
Dec 20, 2006 06:19 |  #13
OK... simple facts. On all Canon digital SLRs (apart from the 1 Series cameras) the AF mechanism is rated to work with lenses with a maximum aperture as small as f/5.6. If it sees a lens with a smaller max. aperture than that, then the camera disables AF.
You can get a "non-reporting" teleconvertor which doesn't tell the camera about the new effective max. aperture or you can tape the pins on a reporting TC in order to fool the camera. However, if you do this, then you are running the AF mechanism outside of specification. In bright light then you might get away with it and it may even work quite well, but in lower light conditions the lens will start to hunt and it may fail to AF completely.
Glenn
My Pictures: Motorsport (external link)/Canoe Polo (external link)/Other Stuff (external link)
iterrier
Joined Nov 2005
Dec 20, 2006 06:41 as a reply to  @ Cadwell's post |  #14
Thank you all for your replies. I will keep this all in mind. Maybe I'll just get the 400 5.6, and see how much I miss I longer reach before I consider a tc.
Joan
30D
Tamron 1.4 TC
Larry ­ Weinman
Dec 20, 2006 07:48 |  #15
The cheap Tamron 1.4 ( the one with only eight contact pins ) works pretty well on the 400 f 5.6. By pretty well I mean tha the IQ is excellent but the AF is a little slow. I tried the Canon with taped pins but found it to be very slugish by comparison.
7D Mark II 6D 100mm f 2.8 macro 180mm f 3.5 macro, MP-E-65 300mm f 2.8 500mm f4 Tokina 10-17mm fisheye 10-22mm 17-55mm 24-105mm 70-300mm 70-200 f 2.8 Mk II 100-400mm Mk II 1.4 TCIII 2X TCIII 580EX II 430 EX II MT 24 EX Sigma 150-600
2,258 views & 0 likes for this thread, 12 members have posted to it.
489 guests, 121 members online
