Just want general thoughts and opinions. I think this will work and is rated around 25 lbs since I need to handle a 5D with a 70-200 IS.
Thanks for any input.
canoflan Goldmember 1,059 posts Joined Jul 2006 Location: Texas, US More info | Dec 20, 2006 16:44 | #1 Permanent banJust want general thoughts and opinions. I think this will work and is rated around 25 lbs since I need to handle a 5D with a 70-200 IS.
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Dec 20, 2006 19:51 | #2 You don't need that monster head. Skip Douglas
Permanent banThanks for the input and time you took to be comprehensive in your reponse.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Dec 21, 2006 08:18 | #4 Yes, the 488RC2 will do just fine with that. No comment on the legs; Skip uses Manfrotto's 3021s and I use an out-of-production set of Manfrotto CF legs (444, IIRC). Jon
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Dec 21, 2006 08:28 | #5 canoflan wrote in post #2428820 Is that your take even if I was to have a 580EX attached with the 24-70 lens (which is quite heavy itself)? I have read that if you are going to the trouble to get the shot, might as well have a tripod that is steady enough for the equipment and I am trying to hedge my bets that my equipment will only get heavier the deeper I am pulled in to the photography abyss. If I were using a Speedlite to illuminate the subject and if the Speedlite would essentially overpower ambient lighting, I probably would not want to use a tripod. The reason for using a tripod is generally to avoid any perceptable camera/lens motion. The very short time of the flash burst - again if it is the dominant light source - will "stop" any action, be it movement of the subject or camera/lens movement. canoflan wrote in post #2428820 Any thoughts on the legs? I really cannot comment on the leg set you mentioned, as I have never handled one. Skip Douglas
Dec 26, 2006 09:28 | #6 Permanent banThanks a bunch for everyones input. I am sticking with what I ordered and I think it will be stable enough. I use a tripod about 10% of the time and when I do, I have plenty of time, space, and capability with it. I have learned the hard way by getting something not quite there, just to sell it later and get what I want at an additional loss.
Many people do not like the RC4 heads because the plate is rather large. I personally use the RC4 and really like it. The plates are large, but they are curved on one side to match the camera curve. If you put the plate forward enough so that it does not stick out past the back of the camera, the plate does not get in the way. At least for me. And it will lock in solid!! -Ryan
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Dec 26, 2006 10:14 | #8 rdricks wrote in post #2446402 Many people do not like the RC4 heads because the plate is rather large. I personally use the RC4 and really like it. The plates are large, but they are curved on one side to match the camera curve. If you put the plate forward enough so that it does not stick out past the back of the camera, the plate does not get in the way. At least for me. And it will lock in solid!! However, the RC4 QR plates can make it difficult to get a 35mm-sized camera (or a lens) with the QR plate mounted into a camera case. Skip Douglas
Dec 26, 2006 11:30 | #9 Permanent banSkipD wrote in post #2446453 However, the RC4 QR plates can make it difficult to get a 35mm-sized camera (or a lens) with the QR plate mounted into a camera case. Canoflan - I would strongly suggest that you actually handle tripod heads with the ...RC2 and ...RC4 quick release systems to compare them. Photos in catalogs or on line do not really indicate the true differences. Great and thanks for the suggestion. I actually did exactly what you said Friday and I like the larger head. I believe that my setup and bags can maneuver fine. If things don't work out, I bought from B&H and have some time to return the item.
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | Dec 26, 2006 11:41 | #10 SkipD wrote in post #2426842 I leave the ...RC2 QR plates on my equipment full time, which is really the intended way to use QR plates - avoiding the requirement to fasten the QR plate to the camera every time you want to put it on a tripod. Hey Skip, Robert
Dec 27, 2006 10:56 | #11 Permanent banWell, I got the combo and it works great. Really sturdy and I can keep the quick connect plate on my 5D and in my small, single camera bag without a problem.
| Latest registered member was a spammer, and banned as such! 2126 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
