Thread started 20 Dec 2006 (Wednesday) 19:02
What is a good focal length?
cheerio0s
Dec 20, 2006 19:02 |  #1
I was just skimming through my Camera's manual, and I just realized what focal length is lol. I also read online that focal lengths for bird watching should be at least 400mm! My camera has 4x optical zoom (70-280mm)
Is 70-280mm a good focal length for bird photography? I highly doubt it, but I'm looking to see if anybody has good pictures of such a focal length
Honestly I still don't really understand a lot of this stuff, but I'm hoping to figure it out eventually. I'm sort of getting an idea though
Canon Powershot A630 STOCK :cry: Nothing else but a 512MB card
canonshooter4life
Dec 20, 2006 19:33 |  #2
It can be good in some situations but for most bird photography the longer the lense the better...it just opens up more opportunities... I have a 75-300 zoom and upgrading to the 400 f5.6 for more reach i would get the 500 if i had the money ... but maybe after i go through university... there is a conservation area here with a bunch of feeders up on the trail and people always go there and feed the birds from their hands so you do not need a long lense...try to find something like this where you are located it is nice to be able to get close for once without much work and would be perfect for what you have...
Brandon
Brandon
Gear: Canon 60D, Canon 400mm f5.6L, Nifty Fifty, Canon 580EX, Kenko tube set, Kenko Pro 1.4X TC (coming next), Bushhawk, Manfrotto 055 ProB, and Manfrotto 322 grip head.
CanonLaw
Joined Jun 2005
Dec 20, 2006 19:34 |  #3
I am going to say that you will probably have a hard time doing bird photography with that camera. I had a G2 for a while, and while it was good for still objects that were close to you, once something started moving, it couldn't keep up. As far as what is a good focal length, that is relative. If you are at a zoo and can get within 10 feet of a stationary bald eagle, you will get some good shots. However, in the wild, most birds don't let you get that close. They will fly away, hence the need for a longer focal length lens. I was using a 300mm for a while and got some good shots, but I also found I had to crop a bit to get the perspective I wanted. I now have a 400mm lens and it has made a world of difference. The following two pictures were taken at 300mm, so it shows you can get some good shots at 280mm, which is close enough.
Sorry for such a long response. I am not an expert bird photographer, but I have been doing this for the past few years so I thought I would share what I learned. To sum it up, you really should have 300mm or more IF you want close up shots. Also, you will be much more successful if you have a longer focal length because you can take a picture from farther away and not scare off the bird.
Hope this helps a little, and good luck. Just start shooting pictures and see what you get. You will know really quickly if that camera's lens will suffice.
IMAGE: http://img.photobucket.com/albums/v462/AmishThug/Eagles/Eagle035.jpg
IMAGE: http://img.photobucket.com/albums/v462/AmishThug/Eagles/robin1.jpg
seanm
Gallery: 25 photos
Dec 20, 2006 20:33 |  #4
You may find this thread useful
https://photography-on-the.net/forum/showthre​ad.php?t=238893
Quite a similar theme.
Sean
C&C welcome.
884 views & 0 likes for this thread, 4 members have posted to it.
641 guests, 120 members online
