Thread started 21 Dec 2006 (Thursday) 09:41
How do you use your monopod?
WildWolf
Joined Feb 2003
Dec 21, 2006 09:41 |  #1
How do you have your monopod positioned (relative to the ground and also to your legs)? Also, how do you have your legs positioned while using your monopod?
Thanks in advance
5DMkIV
Canon 24-105 L IS ; 70-200 L IS II; 100-400 L IS
430 EX; Feisol 3442 w/CB50D; Bogen 681B; POTN strap
SYS
Gallery: 602 photos
Joined Jul 2004
Dec 21, 2006 10:29 |  #2
My monopod (see sig below) adjusts its height by simple trigger motion. It's a really convenient feature, and I use it all the time. It's indispensable when your shooting circumstances require that you move around a lot.
-Goethe
hkdigit
Dec 21, 2006 10:35 |  #3
SYS, do you found your monopod rather heavy?
Chris Lee | My Photoblogs:
Hong kong Photos Blog (external link) , Hong Kong Celebrities (external link) , Hong Kong Stock Photos (external link)
sjafari
Dec 21, 2006 10:43 |  #4
i try to keep the monopod as vertical as possible, using the head for any adjustments i need. Ill have my legs shoulder-width apart, left hand bracing the upper most leg section. I have also kept my monopod in hand as a possible makeshift weapon while walking down some shady areas of Minneapolis.. ill leave one leg unlocked, and within 1 second can have the leg extended and locked, ready for swinging a nice 1lb metal head mounted to a 3 foot pole (havent had to use it yet though :-) )
-Shehab-
http://www.fotojafari.​net (external link)
5Dii, 16-35/2.8ii, 24-70/2.8, 135/2
SYS
Gallery: 602 photos
Joined Jul 2004
Dec 21, 2006 10:43 |  #5
hkdigit wrote in post #2429428 (external link)
Hmmm... actually interesting question because it's never occurred to me to think about it....
Heaviness is relative, so all I can say is that it's heavier than a typical umbrella but less than a household hammer. It's just never occurred to me. Oh, I also use it as a hiking stick...
EDIT: It's 1.19 lbs according to: http://www.bhphotovide​o.com/product/5523/BO3​245/REG/397 (external link)
-Goethe
gjman
Dec 21, 2006 12:34 |  #6
http://www.outdooreyes​.com/photo5.php3 (external link)
I use option 2.
I wonder how long I have to hang out on POTN before I get as good as Ansel Adams ?
SkipD
Joined Dec 2002
Dec 21, 2006 15:25 |  #7
I use my monopod in many ways, depending on the situation. That's why I have a ball head on the top rather than just screwing the camera to the monopod.
I might stand up with the monopod's foot between my two feet and have the monopod fairly vertical - a classical position.
I might be sitting waiting for a particular bird or beast to come to a position that I am ready to photograph it (I could have said "shoot" it, but I'm into firearms too so that didn't sound right). The monopod could be at a 30° to 40° angle to the ground, with the foot of the monopod out in front of where I am sitting.
The monopod might be off to one side if I am in a wierd position such as atop boulders or something like that.
Bottom line - be prepared for using a monopod in many different ways, even as a hiking stick at times. Don't limit yourself to just the classic "stand up behind it" mode.
Skip Douglas
Rumjungle
Dec 21, 2006 15:51 |  #8
Mostly, mine has been used for motorsports, but on one occasion, I used it as a hood prop.:p
Gear
DC9
Dec 21, 2006 16:08 |  #9
From the Dark Side:
http://www.nikonians.o​rg/monopods/ (external link)
blackviolet
Joined Apr 2004
Location: sydney, au (now in singapore for a few years)
Dec 22, 2006 06:14 |  #10
i'm typically shooting sports when using my monopod. so i'm generally running up and down the field and shoot from one knee. generally when shooting rugby league, i wear a plastic capped kneepad on my right side because i've often dropped to my knee to shoot while running and it lets me slide to a stop without falling or hurting myself :)
if i'm shooting surfing, i'm generally standing up with legs slightly spread. i don't use a head on my monopods. i just orient the body portrait or landscape with the tripod collar on the lenses.
oblio
1dmkiii - 5dmkii -Leica M8/M6 - Mamiya 645AFDiii/zd
ModelMayhem (external link) | my (external link)flick (external link)r gallery (external link)
2,096 views & 0 likes for this thread, 9 members have posted to it.
2281 guests, 134 members online
