Thread started 22 Dec 2006 (Friday) 17:22
Monopod: CF vs. aluminium?
delhi
Dec 22, 2006 17:22 |  #1
I'm wondering if the extra weight of an alumunium monopod is better than a CF one. I like CF because it's lighter weigh which will help mobility. Any thoughts?
Vancouver Portrait Photographer (external link)
No toys. Just tools. (external link) :lol:
5d3/1dx AF Guidebook | What AF Points to use for my 5d3/1dx?! (external link)
Jon
Joined Jun 2004
Dec 22, 2006 17:30 |  #2
Weight's not the critical factor in either monopods or tripods - rigidity is. pound/kilogram for pound/kilogram a CF whichever will be more rigid than an aluminum one.
Jon
Cocker Spaniels
ScottE
Joined Oct 2004
Dec 22, 2006 18:09 |  #3
CF is also much more pleasant to work with in cold weather.
NickSim87
Sir Chimp-a-lot
Dec 22, 2006 18:14 |  #4
Chicks dig Carbon Fiber, 'nuff said.
Gear List | Feedback
GPR1
Joined Jul 2003
Dec 22, 2006 18:38 as a reply to  @ NickSim87's post |  #5
I chose CF for my tripod, but aluminum for the mono. My reasoning: the mono was mostly for sports, where I would be close to my car and wasn't lugging it miles. The tripod was for nature and travel, so weight was a premium. It has proved a good compromise.
Greg
--Greg
http://www.expatinchin​a.net/ (external link)
www.facebook.com/Expat​InChina (external link)
kram
obvious its pointless
Dec 23, 2006 04:09 |  #6
I have the CF monopod and tripod. While the CF tripod makes perfect sense coz of the lower weight, not so sure about the monopod. The CF one came to around 1-1.5lbs while the alum one will come to 2.5lbs - both very light to handle.
Canon 7D , Canon 6D, 100-400 L, 24-105 F4 L, 50 F1.4, Tokina 12-24 F4, Kenko Teleplus Pro DG 1.4X Extender
My Gallery (external link)
condyk
Africa's #1 Tour Guide
Dec 23, 2006 04:40 |  #7
My experience is I will use a CF tripod out and about and I won't use a heavier one, so however good the heavier one is it is a waste of time and money.
https://photography-on-the.net …/showthread.php​?t=1203740
dsc_1972
Dec 23, 2006 05:40 |  #8
Metal legs will pick up vibrations, amplify them and transfer them to the camera. CF is much better at damping vibrations.
Dave
JohnJ80
Dec 24, 2006 09:02 |  #9
In the Leica study of a number of tripods from last January 2006, CF was shown to be much better at dealing with vibration from wind (i.e. resonance sort of vibration). CF tripods, although much, much lighter than the biggest tripods in the tests performed pretty much as well as the big heavy beasts. Mass was shown to be the other most important thing and didn't seem to have any benefit based on a particular material.
You can easily add mass to ANY tripod. Just hang your camera bag around the legs or from the bottom of the center column (most give you a hook there). Some will use a tent stake and a shock cord or adjustable nylon cord to that hook.
Because of that ease of adding mass to the tripod, I would much prefer CF for its vibration damping capabilities (which are the benefit).
Rigidity is important in the legs, but having a totally mass coupled unit from the legs through to the camera is not a good idea if the material is a very good transmission medium for vibration. In that case, rigidity is a bad thing. For example, having a steel solid leg to a solid tripod spider (ridiculous case, I know) would be bad. It would transmit pretty much any vibration from the ground straight to the camera.
Here is another good link on tripod performance:
http://markins.com/cha​rlie/report4e6.pdf (external link)
Netting this all out, I would recommend CF over Al anytime. Use the center hook on your tripod to add mass. In this manner, you would have all the benefits of a big and heavy tripod in a smaller, much lighter one.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
1,151 views & 0 likes for this thread, 9 members have posted to it.
2130 guests, 130 members online
