Thread started 17 Feb 2004 (Tuesday) 21:37
Fading Beauty
Crazy ­ Canuck
Gallery: 19 photos
Joined Feb 2004
Feb 17, 2004 21:37 |  #1
Hope I got this right, this is my first attempt at showing a picture. I chose the title for obvious reasons, this rose is in its last stages. Suggestions please.
(alt+p)
Paul
Canon EOS R5, 5D Mark III & 7D Mark II, Canon EF 24-105mm F4 L, Canon EF 50mm F1.8, Canon EF 70-200mm F2.8L IS II, Canon EF 100-400mm F4.5-5.6 L IS II, Speed lite 420EX, Speed lite 600ex-rt, Manfrotto 190X Pro3 Tripod 496 RC2 ball head, Manfrotto 679B Mono Pod 234 RC tilt head
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Feb 17, 2004 22:47 |  #2
Nice image, nice composition..
It is overexposed however.
See the white on the leaves around the base of the rose? They are bright white,. this is called "washed out" or "Blown out" highlights. There is zero color information left,. no way to repair it. When you try this next,. especially with strong lighting, try to bracket the exposure.
I am also concerned that it is not as sharp as it could be. Was this hand held?
When shooting so close where details wil be evident.. it is important to keep the camera form moving at all.. thus a tripod will work wonders..
Nice job. :)
CDS' HOT LINKS
Dawg
Joined Feb 2004
Feb 17, 2004 22:59 |  #3
As said above, correct for washout and maybe use a smaller aperature to get a little more depth of field. It would help if some of the green was in focus.
Keep posting
Dawg :)
ecobo
Joined Feb 2004
Feb 18, 2004 07:49 |  #4
It would be nice if the light was much more softer. And yet it's a good photo.
My Web site (external link) | My FB Page (external link)
Warman
Joined Aug 2003
Feb 18, 2004 10:26 |  #5
I would have to disagree with that, i think the DOF is good and i would even like less if possible. The reason why i believe, you would like more DOF is because forms can clearly be seen in the background which are distracting and because of that you would like them sharper, they bother you being so identifiable but at the same time so blurred. That is however, closely tied with the overuse of light. If this would have been shot with the correct light, you would view the DOF as perfect with the background looking very undistracting. Just mho. :)
http://warman.lusiarte​.net/gallery LusiARTE - My gallery
http://bawarman.devian​tart.com/store - My storefront in DA
http://www.shutterstock.com/g​allery.mhtml?id=2230&r​id=2230 (external link) - Check out My Gallery Here too
Dawg
Joined Feb 2004
Feb 18, 2004 12:25 |  #6
The focus I am looking for is the bud base and the stem the rose sits on. I don't have any problem with the blurred background (maybe more blur as you said).
BTW Thanks for your opinion, I always appreciate the challenge it makes me look again and will help me improve.
Dawg :)
Crazy ­ Canuck
Gallery: 19 photos
Joined Feb 2004
Feb 18, 2004 16:03 |  #7
Could I get a suggestion on what type of equipment you would use and the settings. Being a real newbie I just used my camera as it came with the flash and all. I have a digital rebel, 18-55 stock lense and the built in flash. Thanks for the comments so far, glad I found this forum.
Paul
Kell
Joined Feb 2004
Feb 18, 2004 16:50 |  #8
Well, if shooting so close, you could try using no flash at all, and increase the exposure time if it needs be. Even if the shot turns out too dark, the colour data will still be there, and you'll be able to brighten it in post-processing.
Had the shot been taken at lower lighting, I believe it'd all fit in better. :) As it is, the white leaves are a bit distracting, and I'd bet they weren't really white. ;)
Crazy ­ Canuck
Gallery: 19 photos
Joined Feb 2004
Feb 18, 2004 18:57 |  #9
OK, this picture has a overhead light on with no flash and set on Av mode. The flower is wilting even more now. :(
http://www3.sympatico.​ca/pselvey/rose2.jpg (external link)
Paul
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Feb 18, 2004 20:59 |  #10
This is a technical improvement.
Buy not using the flash you gained two things...
1. Much better exposure,. nothing blown out. Not too dark.
2. By using available light you got a longer shutter speed which reulted in deeper more saturated color.
Two lessons in one.
Now work on your composition and subject.. :)
CDS' HOT LINKS
2,601 views & 0 likes for this thread, 6 members have posted to it.
Fading Beauty
1327 guests, 118 members online
