Thread started 26 Dec 2006 (Tuesday) 07:11
How to correct wide angle distorsion
celter
Dec 26, 2006 07:11 |  #1
I haven't found a method of correcting severe distorsion resulting from using a wide angle lens at an angle, f.ex. when I am shooting a building and pointing the camera upwards. PTLens can correct the distorsion when I shoot an object with the lens paralell to the ground, but not the severe distorsion I get when I point the camera upwards. Can you help me?
5D Classic, 6D, 7D, Canon 16-35 f/4 L IS USM, Canon 24-105 f/4 L, Zeiss 35 f/2, Sigma 50 f/1.4 Art, Canon 100 f/2.8L Macro, Sigma APO 100-300mm f/4 EX IF HSM, Kenko 1.4X, Canon Speedlite 580EX, Canon Speedlite 90EX, Benro C-227, Benro KS-1, HP Photosmart 8750
René ­ Damkot
Dec 26, 2006 08:47 |  #2
I think what you are referring to is 'keystoning'. In photoshop it's fairly easy to correct by using 'transform'.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
PuR ­ HART
Joined Jan 2005
Dec 26, 2006 08:53 |  #3
Rene's right on that go to edit, transform,perspective. also make sure your layer if only one is unlocked.
hope this helps
www.ryancharlesphotogr​aphy.com (external link)
Bodies:
20D and 30D
Lenses: 17-55 2.8IS,70-200 2.8IS,17-85 4-5.6IS,50 1.8,100 2.8
macro
celter
Dec 26, 2006 09:09 as a reply to  @ PuR HART's post |  #4
Thank you guys. You are as always a big help.
JMHPhotography
Dec 26, 2006 16:55 |  #5
Another way to fix this is with a built in filter to Photoshop... filters/distort/len correction. You can fix horizontal and vertical perspective distortion and any combination of both at the same time... AND you can fix barrel or pincushion distortion. Keep in mind though, as with any editing you do in JPEG mode, you risk destroying pixel data so your results (while probably quite acceptable) will never be optimal... with either method. The best way to correctly capture images of subjects while pointing up is with a T/S lens if you want true perspective.
Here's an example of a lens distortion adjustment that I made with the lens correction filter. You can see how extreme the problem was and the results yielded.
~John
(aka forkball)
Have a peek into my Gearbag. and My flickr (external link)
editing of my photos by permission only. Thanks
litwinphotography
Dec 26, 2006 20:45 |  #6
great tips!
http://www.litwinphoto​graphy.com (external link)
Sell your photos At Shutterstock (external link) and make $$ NOW!
Dreamstime (external link) is a sweet place to make some extra cash selling stock!
PuR ­ HART
Joined Jan 2005
Dec 26, 2006 21:45 |  #7
blah thats the one i ws thinking about also could not remeber were she was
Bodies:
20D and 30D
macro
PuR ­ HART
Joined Jan 2005
Dec 26, 2006 21:45 |  #8
Bodies:
20D and 30D
macro
970 views & 0 likes for this thread, 5 members have posted to it.
Latest registered member is slipper1963
1863 guests, 159 members online
