Thread started 26 Dec 2006 (Tuesday) 07:55
Physics for the Brainiacs
MDJAK
Dec 26, 2006 07:55 |  #1
Okay, ladies and gents, put your thinking caps on and educate me, the village idiot.
As the focal length of a lens increases, the field of view narrows.
Have I got that right?
If I do, what, if anything, can be done to eliminate that?
Hold the kudos, as I came up with this in my sleep and woke up to run down here and post it.
Would it be possible to have, say, a 300mm lens with the same field/angle of view as, say, a 24mm lens?
What field of view does the Hubble have? Does it see a swath as wide as a 16-35?
Have at it, peoples.
me
RuggerJoe
Dec 26, 2006 08:58 |  #2
The whole point of having longer lenses is to narrow the field of view. Thus giving a higher resolution to a smaller area which is what alows the magnified view.
Joe
Comments / critiques always welcome.
http://www.flickr.com/​photos/ruggerjoe/ (external link)
Canon 350D
EF-S 17-85 IS USM | EF 50 1.8 | EF 70-300 IS | 580EX | a couple of kit lenses
All of which are all better than my skills.
gjl711
Dec 26, 2006 09:11 |  #3
Well, there is a way but it's kind of goofy. You can accomplish what you speak of bu having a variable size sensor. Then as you focal length increases, your sensor size increases as well to match. That way you can have a 100mm lens on one camera match a 50mm lens on the other.
But, your quickly going to get to the edges of your optics in the process so, You'll also have to invent variable size glass as well. So, then when you zoom out from 50,, to 100mm, not only does you sensor grow, but your lens grows as well.
But wait, this won't really work then all you'll have is a bigger camera and lens. dang!!!
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
stupot
Dec 26, 2006 10:48 |  #4
gjl711 wrote in post #2446302 (external link)
...So, then when you zoom out from 50,, to 100mm, not only does you sensor grow, but your lens grows as well.
hehe:)
Canon EOS 350D, Sigma 10-20 f4-5.6, 24-105 f4L IS, 70-200 f4L, 300 f4L IS, Kenko 1.4x pro300, 430EX, Apple Powerbook G4
Free filters for your flashgun!
20droger
Dec 26, 2006 11:02 |  #5
MDJAK wrote in post #2446130 (external link)
me
Assuming the lens is for use with a given camera, the short answer is NO!
Field of view, or more accurately angle of view, is a property of the focal length of the lens and the size of the sensor. The equation for angle of view is:
A = 2arctan(d/2f)
where:
A = angle of view;
arctan = "the angle whose tangent is";
d = the dimension of the sensor/film in the measuring plane ("d" is from "diameter of the image circle"); and
f = the focal length of the lens.
For a full-frame 35mm sensor (or 35mm film), the image is 36×24mm. This produces a diagonal of 43.27mm. This 43.27mm is the size of the image circle.
For your 300mm lens on an ff35 camera, the angles of view are:
36mm (horizontal) plane = 6.87° (most useful AoV)
24mm (vertical) plane = 4.58°
43.27mm (diagonal) plane = 8.25° (least useful but most cited AoV)
If you put the same lens on an EOS-1D MkIIn, which has a sensor size of 27.8×19.1mm, with a diagonal of 33.73mm, these angles of view become:
27.8mm (horizontal) plane = 5.31°
19.1mm (vertical) plane = 3.65°
33.73mm (diagonal) plane = 6.44°
Again, if you put the same lens on an EOS 30D with a 22.5×15mm sensor, with a diagonal of 27.04mm, the angles of view become:
22.5mm (horizontal) plane = 4.30°
15mm (vertical) plane = 2.86°
27.04mm (diagonal) plane = 5.16°
The smaller the sensor, the smaller the angles of view for a given lens. This is the basis of the so-called "crop factor," which is 1.2544 for a 1D (NOT the published 1.3) and 1.6 for a 30D.
I don't happen to know either the focal length or the sensor size for the Hubbel telescope. It is, however, not a "telescope" in the traditional meaning of the word, but rather one hell of a digital P&S camera.
Ronald ­ S. ­ Jr.
Prodigal "Brick" Layer
Gallery: 12 photos
Dec 26, 2006 11:18 |  #6
I'm missing something. Why do you want, for example, a 300mm lens with a 24mm fov? Just use a 24mm, you goof.
Mac users swear by their computers. PC users swear at theirs.
20droger
Dec 26, 2006 11:21 as a reply to  @ 20droger's post |  #7
The Hubble telescope has a focal length of approximately 58.6m (58600mm) and a circular sensor with a diameter of 2.3399m (2339.9mm). This gives it an angle of view of 2.2875°
This is approximately the same angle of view as a 1083mm lens on an ff35 camera.
The Hubble telescope is a super-telephoto fixed-focal-length digital P&S camera.
A little big for birding, though.
I wonder how many megapixels are in that 2.3399m diameter sensor. Think it's as sharp as a 1Ds MkII?
gjl711
Dec 26, 2006 12:27 |  #8
20droger wrote in post #2446646 (external link)
The Hubble telescope has a focal length of approximately 58.6m (58600mm) ....
A nifty fifty on the Hubble. Isn't that just like NASA. Spends all the money on the body and tosses on the cheapest lens. Maybe it's time for NASA to upgrade to a red ring. ;):D
::Gear::
20droger
Dec 26, 2006 12:40 as a reply to  @ gjl711's post |  #9
Look more closely, that nifty fifty has a focal length of 58.6 meters.
Remember the trouble the originally had with the mirror? Well, what did they expect! The mirror was made by a division of GM, the same folks who give you car mirrors with the etching, "Object in mirror may be closer than they appear."
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Dec 26, 2006 12:48 |  #10
Easy. Get further from the subject.
Spielberg loves this technique. I first noticed it in Jaws, where chief Brody sees (or thinks he sees, I forget which) the shark amid all the holiday swimmers there is a shot were the camera zooms in on his face, but the FOV remains the same.
In film it is called a "Dolly Zoom", and was invented sometime in the late 1940's or early '50's. It is accomplished by simultaneously zooming in AND pulling back (on a dolly to insure smooth motion). By increasing the focal length and increasing distance you keep the same field of view on the subject, but, the background changes quite unsettlingly.
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
gjl711
Dec 26, 2006 13:24 |  #11
20droger wrote in post #2446895 (external link)
Look more closely, that nifty fifty has a focal length of 58.6 meters....
Whoa!!! Thats a bit different. So it's one great big nifty fifty. :D
::Gear::
DavidEB
Dec 26, 2006 13:26 |  #12
you can get a bigger field of view by using a bigger sensor, with the same focal length lens.
David
my stuff - [URL="http://www.pbase​.com/davideb"]my gallery - [URL="http://photograp​hy-on-the.net/forum/showpost​.php?p=3928125&postcou​nt=1"]go Rats!
Zepher
Joined Nov 2005
Dec 26, 2006 15:11 |  #13
Radtech1 wrote in post #2446914 (external link)
Rad
In Jaws they were already zoomed in and were going wide AND moving forward.
Manny Desantos
Intel C2Q Q6600 3.06Ghz, 8GB Ram, 8.1TB, XFX HD5850, Windows 7 Ultimate 64bit, PS CS4 EXT (external link)
Canon 40D, EF 28-70L, 2x Canon XH-A1 HDV, Canon HV30 HDV
❶_______________
Jon, ­ The ­ Elder
teaching fish to ride a bicycle
Joined Oct 2004
Dec 26, 2006 17:44 as a reply to  @ Zepher's post |  #14
RAD & Zepher....Thanks guys, brought back old industrial movie days. I liked the Chapman series of dollies (they seem smoother ) I had a special "dollie dwarf" I worked with by the name of Dave Reynolds (good gaffer too). We worked up some pretty complex shots that still have people asking 'how'd they do that?
By the way the term 'dollie dwarf' is not a demeaning term, but rather one of status. It basically comes from their croutching down to avoid any chance of spoiling the shot. And yes they are FIT. With a 16/35mm film cam and gear + the PA on an outrigger with monitor in lap and a focus puller on the other side, it takes a tremendous amount of strength and skill to bring that load to a precise stop and no camera backlash at the end.
A 40D, a 30D, some nice glass and a great Shooting Partner.
"...As in music, so in life."
BrewsterPilot
Dec 26, 2006 17:47 as a reply to  @ Jon, The Elder's post |  #15
That avatar really suits you...
1,812 views & 0 likes for this thread, 12 members have posted to it.
2418 guests, 106 members online
