Thread started 26 Dec 2006 (Tuesday) 20:44
selecting dark objects from dark backgrounds
steve547
Dec 26, 2006 20:44 |  #1
I have trouble using the lasso or magic lasso tool in photoshop when it comes to finding the edges of a persons hair against a dark background. The edges become clear if I brighten the entire picture and then use the lasso tool. But how can I revert to the original(unbrightened) photo then without losing the lasso selection. Or is there a better way to select objects from background of similar color?
Steve
_____
EOS 20D, EOS 5D MARK III,18-55mm kit lens, Canon 35mm/f2, Canon EF 24-105 f/4L IS USM, Canon 220EX, Sigma EF-500 DG ST, G2, Canon i960 photoprinter, Canon Pixma Pro 9000 printer, Tamron 17-50 f2.8 non vc.
PacAce
Joined Feb 2003
Dec 26, 2006 21:18 |  #2
steve547 wrote in post #2448386 (external link)
Create a duplicate layer of the image you are working on. Increase the brighness level of the duplicate layer so that you can differentiate the hair from the background. Once you have the selection completed, click on the eye on the duplicate layer to make it invisible or just drag that layer in the layer palette to the trash bin at the bottom right of the palette to discard it if you no longer need it. Then click on the image layer to make it active.
...Leo
hard12find
Dec 26, 2006 21:23 |  #3
Steve,
Duplicate layer brighten and contrast to higher levels, make selection, save selection under select menu, name it, delete duplicate layer, load selection under select menu.
Hope that helps....Jim
20D, 10D, Fuji S-20, Mamiya C220 medium format, Sekonic L-508 meter, 2 alien bee 800's, AB remotes, Sigma 500 HS flash, 70-200 F2.8 L, Sigma 24-70 F2.8 EX DG, lots of glass, lots of stuff,8-)
PacAce
Joined Feb 2003
Dec 26, 2006 21:23 |  #4
Another trick you can use is after you have made a selection, you can save the selection by clicking on Select on the menu bar and then selecting Save Selection. Once a selection is saved, it can be reloaded with Select > Load Selection.
...Leo
steve547
Dec 27, 2006 20:18 as a reply to  @ PacAce's post |  #5
Thank you Leo and Jim for those instructions. I've been trying to figure this out for a long time. I should have asked sooner. Thanks again. Steve.
Steve
_____
PacAce
Joined Feb 2003
Dec 27, 2006 20:26 |  #6
Here's another tip for you. Once a selection is saved, it becomes an alpha channel which is accessible via the Channels palette. You can select an alpha channel and edit it using black and white colors to add to or remove from the selection. You can also use the Blur filter to soften the edges of the selection if you wish.
...Leo
steve547
Dec 28, 2006 20:50 as a reply to  @ PacAce's post |  #7
Thanks again. I appreciate all this advice and I'm trying it all out.
Steve
_____
2,547 views & 0 likes for this thread, 3 members have posted to it.
998 guests, 109 members online
