Thread started 27 Dec 2006 (Wednesday) 11:27
PS3 and ACR Problem
Chazs
Joined Aug 2002
Dec 27, 2006 11:27 |  #1
Has any body else seen this problem, and what can I do about it....
In PS3 Beta, the Raw Converter screen is too large. I can't see the Save Cancel Open and Done buttons, ! I've tried changing my monitor settings, but to no avail. Currently my monitor is at the highest 1024x768, 32-bit color settings. If I ever get PS3, it may need to be accompanied with a newer monitor. I hope not. Any suggestions? (PS2 ACR is okay.)
Ander
Dec 27, 2006 12:10 |  #2
You can change this window size, by dragging it from right bottom corner.
Ander
Canon EOS 1D Mark III, EOS 30 D, IXUS 850 IS, EF 17-40 L, EF 24-105 L IS, EF 70-200 f/4 L IS, EF 100-400 L IS, EF-S 10-22, 580 EXII Speedlite, 420 EX Speedlite
Chazs
Joined Aug 2002
Dec 27, 2006 12:26 as a reply to  @ Ander's post |  #3
Well, number 1, I can't get to the bottom right corner, and number 2, I can't move the ACR window up to get to anything on the bottom. Even Alt-Space doesn't bring up the move command. I think Adobe may have to take a look at this.
René ­ Damkot
Dec 27, 2006 12:41 |  #4
If you can't see the bottom right corner, switching to a higher screen resolution (even at 256 colors; who cares), and adjusting the size of the window might do the trick...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
sjafari
Dec 27, 2006 12:57 |  #5
at 1280 x 800, my taskbar has to be minimized to the bottom if i want to see all the buttons. Resizing will work both ways horizontally, but will reach a vertical minimum limit when resizing. Its pretty annoying, but id be a lot more annoyed if i had a 1024*768 screen.
-Shehab-
http://www.fotojafari.​net (external link)
5Dii, 16-35/2.8ii, 24-70/2.8, 135/2
tiktaalik
Joined Feb 2006
Dec 27, 2006 14:22 |  #6
I have this problem too and for those of us with monitors with a max resolution of 768 x 1024 are stuck. It's a known bug and it will be fixed for the release.
Julie
My galleries (external link)
https://photography-on-the.net …hp?p=1330884&po​stcount=56
Chazs
Joined Aug 2002
Dec 27, 2006 17:24 |  #7
tiktaalik wrote in post #2451144 (external link)
Excellent. Thanks for the info. I'll kill some more time playing with it.
1,281 views & 0 likes for this thread, 5 members have posted to it.
PS3 and ACR Problem
1229 guests, 150 members online
