Thread started 27 Dec 2006 (Wednesday) 11:42
Pelican takeoff - Bay of Banderas, Mx
timc
Gallery: 146 photos
Dec 27, 2006 11:42 |  #1
I took this picture with a S 2IS set to ISO200, AV from a path above the bay. Is there a way to improve the details in photoshop? Thanks.
IMAGE: http://i82.photobucket.com/albums/j249/timjc/IMG_0388.jpg
canonloader
Gallery: 6 photos
Dec 27, 2006 12:25 |  #2
In CS2, I adjusted the shadows and highlights a little and did a double pass of Unsharp Mask set to 100, 0.3, 0.0. It also helps if you have a place to host your images so your not limited to 100k by the attaching them to the forum server.
Mitch- ____...^.^...____
timc
Gallery: 146 photos
Dec 27, 2006 12:35 as a reply to  @ canonloader's post |  #3
Canonloader,
Thanks, that really makes a difference. What software did you use to make the adjustments? Is it expensive?
canonloader
Gallery: 6 photos
Dec 27, 2006 12:40 |  #4
I used Photshop CS2, and yes, it's too expensive. Although, I think Elements might be able to do the same thing, and I think there are free copies around bundled with some Canon camera software. You might Google for Photoshop Elements.
timc
Gallery: 146 photos
Dec 27, 2006 12:59 as a reply to  @ canonloader's post |  #5
Thanks again. I'll give it a look. Taking the picture is just the beginning of the process I guess...
canonloader
Gallery: 6 photos
Dec 27, 2006 13:03 |  #6
Yup, digital takes a lot of processing to get top notch images. It would help if you raise the ISO or the aperture so you can shoot at a faster shutter speed. That helps a lot to make the blurred areas sharp. 1/160 isn't quite enough to stop the action or camera shake.
1,135 views & 0 likes for this thread, 2 members have posted to it.
1392 guests, 136 members online
