Thread started 28 Dec 2006 (Thursday) 05:15
Manfrotto 190PRO B / 488RC2 Question
kevin_c
Dec 28, 2006 05:15 |  #1
I have not been using my old Velbon D-700 video tripod legs and a Manfrotto 141RC 3 way pan & tilt head as much as I should, It's mainly because it's so bl**dy big & heavy!
I want a lighter/smaller unit that will not cost a fortune - about £100 max if poss.
I have already bought a Manfrotto 488RC2 ball head and this is great and also weighs less than the old 141RC (0.3kg less), It also does not have the adjustment arms to stick into me as I carry it!
Been looking at the Manfrotto 190ProB legs for about £85. I know they are not as stable, and tall as the 055, but that's the same weight/size as my Velbon (2.4kg). The 190 is only 1.9kg, and along with the 0.3kg weight saving of the new head I'm sure will make all the difference to me actually using it more.
The main question is... (at last!) Will this setup be stable enough to carry my 20D with Grip with a Sigma 70-200 f/2.8 or 24-105L fitted. I know the head is up to the job, it's the legs I'm concerned about.
I'm not usually interested in going out when it's blowing a gale, so as long as it's stable in 'normal conditions' I'd be happy.
Anyone else have this setup - are you happy with it or not?
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
philbyuk
Gallery: 52 photos
Joined Nov 2005
Dec 28, 2006 05:55 |  #2
i have precisely this setup sturdy enough for me ....with the 70-200 ive yet to try it with the 100-400, but im sure it will be good enough with that setup.
My 365 '2018' (external link)
Olegis
Joined Apr 2004
Dec 28, 2006 06:02 as a reply to  @ philbyuk's post |  #3
I use the 190PRO + 486RC2 setup with my 10D and 70-200 f2.8L with no problems. Don't use the center column much, though.
Best wishes,
Oleg.
www.Olegis.com (external link)
My equipment list
'I take orders from no one except the photographers' – Harry S Truman
SkipD
Joined Dec 2002
Dec 28, 2006 06:03 |  #4
kevin_c wrote in post #2453835 (external link)
If you wind up frequently needing to extend the center column to gain the height that you need, the rig will NOT be as stable as a taller tripod leg set such as the 055ProB. One should, in my opinion, choose a tripod that is tall enough to be used without extending the center column most of the time.
There are exceptions. Some tripods have very large diameter center columns that are very stiff and do not detract from the tripod's rigidity when extended. The family of tripods we are discussing, however, does not fit this description. They are far superior to the department-store cheapies, but I still would not want to work with a heavy long lens on a fully extended center column with my 3021BPro (same as the 055ProB).
Skip Douglas
Ephemeral
Dec 28, 2006 11:11 as a reply to  @ SkipD's post |  #5
I have used my tripod with a 5D with grip and 70-200 f/2.8 IS and it's stable enough for my needs.
Canon 5D + Grip | 85mm L f/1.2 | 17-40mm L f/4.0 | [COLOR=Silver]24-70mm L f/2.8 |[COLOR=Black] 70-200mm f/2.8 L IS | Speedlite 580EX & 430EX | Manfrotto 190Pro + 488RC2
ephemeral.smugmug.com (external link)
kevin_c
Dec 28, 2006 11:58 |  #6
philbyuk wrote in post #2453891 (external link)
Thanks philbyuk - I don't intend getting anything bigger than the 70-200 I already have.
Olegis wrote in post #2453907 (external link)
I don't intend using the centre column, unless i really have to - Thanks
SkipD wrote in post #2453909 (external link)
Thanks Skip, As I said to Olegis ^^^ I don't intend using it with the centre column up, I really want to get this to make me use it out and about, when I would not have taken the heavy old Velbon (and therefore maybe an 055) so I realise it's not the best choice as far as height & stability goes, but I think it will do for my uses, I'm now happy it will take the weight OK and not buckle under the strain!
I'm keeping the Velbon so if I ever do need the extra height/stability I can use it.
It's really all a comprimise I know, but the main reason I don't use the old one is because it's so big & heavy, so I'm hoping this may make me use it more.
Ephemeral wrote in post #2454901 (external link)
Thanks Ephemeral - That's what I want to hear, I've been thinking that my next DSLR may be a FF (5D replacement next year??)
-- K e v i n --
kevin_c
Dec 30, 2006 14:35 |  #7
OK, an update - I decided to get the 190 and so far I'm impressed - great build quality and a lot lighter than my old setup, so with a bit of luck I'll use it more :-) I seems pretty sturdy enough for my uses as well.
I do agree with Skip's earlier comment about the centre column though, with the centre column up it does get a bit 'wobbly', but the height of the 3 section legs is adequate for me. If I were shooting at eye level all day I'd have a bad back, but I tend to use it lower down anyway.
Thanks for all the replies...
-- K e v i n --
Nick_C
Dec 30, 2006 14:43 |  #8
I got the 190Pro for Christmas along with the 804RC2 head as I don't like ball heads, its a great setup, a little bulky to carry but no more than any other tripod, I have got used to the lightness of my £2.50 tripod (yep £2.50) its cheap & is made by Cosmo, but it was nice & light, but this 190 is far better built, its pretty stable.
Nick :-)
Vini
Dec 30, 2006 14:54 |  #9
I have the 190 pro too. As a habbit, i clip my Lowerpro mini trecker to the centre column, this makes it much more stable when the centre column is extended.
MY PHOTOS
http://www.flickr.com/​photos/viniryan/ (external link)
MY GEAR LIST
[350D] [KIT LENS] [17-40L:D ] [SIG 105 MACRO] [SIG 70-300] [KENKO EX TUBES] [430EX] [FLASH BRACKET] [BG-E3 BAT GRIP] [MANFROTTO MONO+TRIPOD] [AND LOADS OF BITS]
Mick ­ Emmett
Dec 30, 2006 20:13 |  #10
I tried the 190 in the shop with my 20D; grip and 100-400L on it and it was a little shaky, tried the same set up on the 055 Pro and it was steadier; not by a lot but enough to make me go for the 055 and the 486RC2 ball head with Quick release.
Dorman
Joined Feb 2006
Dec 30, 2006 20:25 |  #11
Love my 190, should serve you just fine.
kevin_c
Dec 31, 2006 04:10 |  #12
Thanks for the further comments people...
I almost went for the 055, but I was not going to loose any weight, although the new head makes is a lot easier to carry than my old one (3 way pan & tilt).
The whole reason for changing was to make it lighter, I can't afford a decent CF one (well, I could, but I'd have to go without food for a month!) so it all came down to the 190PRO or similar.
I've heard about the Dynatran ones on ebay, but didn't like the leg releases on the ones I saw, plus I didn't want to possibly get 'stung' for import taxes etc.
If the weather brightens up here (I don't think it will) I may actually get to use it outdoors! on some dull grey landscapes :-)
-- K e v i n --
1,655 views & 0 likes for this thread, 9 members have posted to it.
1939 guests, 129 members online
