Hey everyone, i just bought myself a new b+w circular polarizer and am unsure of how to clean it best. I need your help on how to get the best clean of this filter.
thanks
604Shooter Member 62 posts Joined Sep 2006 Location: Vancouver, B.C. More info | Dec 28, 2006 20:08 | #1 Hey everyone, i just bought myself a new b+w circular polarizer and am unsure of how to clean it best. I need your help on how to get the best clean of this filter. Photoshop, lots of it.
dsc_1972 Senior Member 458 posts Joined Oct 2006 Location: Edinburgh, UK More info | Dec 28, 2006 20:26 | #2 Lens cloth or one of those microfibre cloths you get in household stores will be fine. Dave
Dec 28, 2006 20:36 | #3 Should i use any sort of fluid on it?I heard that the fluid can ruin a coating or something. Photoshop, lots of it.
JKSeidel Member 111 posts Joined Oct 2006 Location: Miami, FL More info | Dec 28, 2006 20:58 | #4 604Shooter wrote in post #2457240 Also i have a "pre moistened lens(glasses) towlette" it says it has isopropanol. Will that work well? Towelettes used for cleaning glasses tend to leave fibers (lint) behind that are very apparent if you hold the filter at an angle after trying to use one. They aren't really suited for cleaning photographic lenses and filters, at least in attempts I've seen in using them. As with all coated glass, you should handle them with care and clean them as infrequently as possible. Coatings will break down over time and lose effectiveness. As previously suggested, obtaining a quality microfiber cloth and a minimal amount of lens cleaner is the best way to go. Make sure to use a fine soft brush and/or air blower to remove any grit prior to wiping down a lens or filter or you risk having the cloth drag grit over the surface leaving scratches. Jeffrey
Dec 29, 2006 01:42 | #5 thanks! Photoshop, lots of it.
Tsmith Formerly known as Bluedog_XT 10,429 posts Likes: 26 Joined Jul 2005 Location: South_the 601 More info | Dec 29, 2006 06:59 | #6 Lens tissue paper is what I've found to be best, lent free and only use a small amount of cleaning fluid.
JKSeidel Member 111 posts Joined Oct 2006 Location: Miami, FL More info | Dec 29, 2006 07:03 | #7 604Shooter wrote in post #2458306 can i use one of those microfiber cloths you get with your sunglasses Those work fine. Jeffrey
BlueS2 Goldmember 1,352 posts Likes: 1 Joined Aug 2004 Location: US More info | Dec 29, 2006 07:52 | #8 What about a PEC pad and some eclipse fluid? Canon 5DmkII / Canon 5D / LifePixel IR 350D / L-glass
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Dec 29, 2006 08:09 | #9 Eclipse doesn't work very well on lenses - it leaves some serious streaks. You can take my 100-400 L away when you pry it from my cold, dead fingers.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Dec 29, 2006 10:17 | #10 Streaking is easily remedied if you simply fog the surface with your breath and the wipe it with a microfiber cloth. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Dec 29, 2006 11:53 | #11 Any product that leaves something on the lens is not doing a very good job *cleaning* in my opinion. Why would I "clean" with something that leave the lens dirty? You can take my 100-400 L away when you pry it from my cold, dead fingers.
aericj Goldmember 1,240 posts Joined Sep 2003 Location: Louisville, K USA More info | Dec 29, 2006 12:13 | #12 Primarily a blower and/or brush since it is usually just dust on the filter. If the filter does happen to get a fingerprint or other mark I usually just wipe with the edge of a cotton shirt or microfiber cloth if handy. I occasionally use a lenspen for stubborn spots - but it is very rarely needed. I also use warm water and a bit of dish soap if the filter is really dirty from sea spray or something - and then dry it with a microfiber cloth. Canon Ti5 w/ 18-135 IS STM, 70-300 IS, 85 1.8
scottbergerphoto Cream of the Crop 5,429 posts Likes: 1 Joined Jun 2003 Location: Brooklyn, NY, USA More info | ROR and Pec Pads works for me. I just ordered some Rexton Lens and Optical Surface Cleaner which is also supposed to be excellent, from http://www.surplusshed.com/pages/item/m2634.html One World, One Voice Against Terror,
DavidW Goldmember 3,165 posts Likes: 1 Joined Jul 2005 Location: Bedfordshire, UK More info | Dec 29, 2006 17:26 | #14 I have some Formula MC fluid which I use, together with lens tissues, if I need to wet clean my B+W MRC filters. Normally a quick blow off and possibly the gentlest of attention with a LensPen (which I use cautiously, but it can be used in the field) is all that's needed.
Azzure_7 Goldmember 1,102 posts Joined Nov 2006 Location: Austin, TX. Singapore, Bogor, Indonesia. More info |
| Latest registered member is IoDaLi Photography 1733 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
